Rivet snap dimensions
Home Forums Beginners questions Rivet snap dimensions
Viewing 25 posts - 1 through 25 (of 47 total)
  • #5823
    geechr
      @geechr
      geechr
        @geechr
        I recently bought, online, a 3/32″ rivet snap. When I received it I was surprised how large the indentation in the snap to produce the rivet head was (3/16″ diameter on the OD). The snap also allows you to “set up” the rivet and the hole OD in the snap to allow this operation is 9/64″. When I tested out the snap I obtained poor results so I concluded that the snap must be incorrect so I sent it back and requested the correct item. I received the same rivet snap back.
        Before I return it again I want to make sure that my suspicions are correct or perhaps I an not using the tool correctly.
        My questions are: –
        1. Are the dimensions quoted above correct for a 3/32″ rivet snap?
        2. What does setting up a rivet mean?
        Chris Gee
        #80835
        Terryd
          @terryd72465
          Hi Chris,
          The head of a round head rivet is nominally twice the diameter of the shank, so a 3/16 dia rivet would have a head of 3/16. So your ‘snap’ appears to be correct.
          As I was taught, the ‘setting’ of a rivet is the process whereby the parts to be held by the rivet are closed together tightly before the rivet is finally formed. So the rivet would be inserted in the close fitting holes in the parts to be held, the head is supported somehow – usually in a second snap – and the loose setting hole placed over it and hammered down to close the parts together, hence the loose fit in the snap. You can make a set to do this latter with just a hole in a length of carbon steel and hardening and tempering to blue making sure that the business end is well finished so as not to mark the work.
          I may be teaching grandmother to suck eggs, but the snap cannot be used to form the head, only finish it. After the rivet is set (assuming it has been cut to the correct length), the head must be rough formed by ‘peening ‘ with a hammer. This is done with the half round part of the ball peen hammer. The half round set is only then used to finally finish off the head to a good half round shape. The picture gives a better idea of how it is done. The two parts would have been set tightly together before peening.
          Best regards and good tidings,
          Terry
          #80836
          Brian Price
            @brianprice19431
            Hi Chris
            It is a long time since I have done this type of riveting but I have gleamed the following info from my machinery handbook.
            For snap or round head BS small rivets
            Shank diameter 3/32″
            Head diameter 0.164″
            Head height 0.070″
            Unfortunately I don’t have tables for the length of shank needed to form a good head for rivets below 1/2″ diameter.
            I tried to find a picture of a rive snap set but if my memory is correct there should be one tool to support the already formed rivet head whilst you hit the other end.
            Another tool with a straight clearance hole that is used to make sure the two plates are set flat together,
            Then the rivet is peened over with a ball pein hammer
            Then there is a female mushroom on the punch to finally form the rivet head, usually combined with the setting punch.
            I hope this helps
            #80837
              The head dia for a 3/32″ rivit should be 1.75D so 0.164″ with a height of 0.75D so 0.070″
              How well does a rivit sit in the snap, if its a bit below the surface then maybe grind down the end of teh snap.
              Setting a rivit is done with a hollow punch or a setup & snap like you have, it basically makes sure all teh layers to be rivited are pressed well together so the rivit won’t expand into gaps between teh layers, I would expect the hole to be a littel over shank dia but yours does sound a bit large.
              Have to disagree with Terry, the snap can be used to form the head, as this pic confirms along with the use of rivit squeezers and larger hydralic machines.
              J
              Edited By JasonB on 30/12/2011 17:15:17
              #80866
              Sub Mandrel
                @submandrel
                I made a serviceable snap for 1/16″ rivets by drilling silver steel with the tip of a 1/8″ drill, heating to red heat and then whacking a 1/8″ ball in the hole with a big hammer, followed by harden and temper.
                I had to do a little grinding off the length to get the best results.
                geechr
                  @geechr
                  Thank you for the quick and useful information. I wonder whether my problem is the length of the rivets? Perhaps they are not long enough and that is why I am not obtaining well formed heads. How much of the rivet should protrude from the materials being joined?
                  Chris Gee
                  #80883
                  mgj
                    @mgj
                    Perhaps a lot depends on how much force one has available, and how soft the rivet is. .
                    Certainly you can form the head of a rivet just using a domed snap, but Terrys system is easier, and best is the use of a set up and then a conical snap and finally a domed finisher. The problem being, starting with a domed snap is that its quite easy to offset the head, and once its been knocked off line, its difficult to get all straight again.
                    The bigger presses tend to use guided snaps/dollies, which makes a difference. I shall be doing a 4″ TE shortly, with 3/16 and 1/4″ rivets. A guided dolly is the way to go there, along with a 10 ton press! The other alternative, where visibility is less of a problem, is to knock the rivet into a countersunk hole, which gets away without forming a second head at all – if that suits the circumstances.
                    There are various charts for head size etc, but snaps do differ, and its probably worth experimenting on a bit of scrap first. Once things are setting right, you know how much to allow.
                    #80890
                    Terryd
                      @terryd72465
                      Posted by geechr on 30/12/2011 23:01:52:
                      Thank
                      Chris Gee
                      Hi Chris,
                      The shank of the rivet should protrude by 1.6 diameter.
                      The
                      diameter of the rivet head is a shown in this extract from a
                      manufacturers table. as you see the max allowable size for the rivet
                      head is 0.185″ which is a few thou short of 3/16 (0.1875″).
                      Terry
                      #80897
                        Terry where do you get your 1.6D from? I usually cut just below 1.5D and thats backed up by the table I linked to in my post above at 1.43D
                        As mgj says it may need a bit of adjustment up or down to suit your specific snaps, aim for a formed head that looks like the manufactured head as much as possible.
                        Also when doing things like traction engine wheels you have no choice but to use punches/snaps as you cant get all round the rivit with a ball pein hammer
                        J
                        #80899
                        Terryd
                          @terryd72465
                          Hi Jason,
                          That was what I was taught and have seen in various reference books over the years. I can’t guarantee that it’s correct.  As you will be aware, mistakes are often repeated in books and the internet as many texts are partly plagiarised, or copied and information is often repeated ad verbatim without corroboration. In this case the difference would be about 9 thou and when set would make very little difference to the shape of the head when set, but I am more than willing to bow to your expertise.
                          I set and formed many rivets over my career and never had much of a problem, but then I have always had full access to the head of a rivet and have been able to peen the head first as per formal practice. The shorter shank length would certainly help to prevent distortion of the shank if using the snap alone to form the heads.
                          In full size practice of course I would expect that the rivets would be hot set with specialised equipment as in Locomotive practice.
                          Best regards of the season,
                          Terry
                          Edited By Terryd on 31/12/2011 09:36:19
                          #80900
                          mgj
                            @mgj
                            Next problem – if one is cutting rivets to a length – how to do it quickly? Is there an answer.
                            I find if I use cutters and so don’t get a nice square end the shank tends to tip leaving an “offset” or malformed head. So its down to hacksawing many rivets – long time slow.
                            Hammering them – work of a second or so with an air hammer, but cutting to length?
                            Any solutions? Or is this just one of the little joys of model engineering?
                            #80901
                            David Clark 13
                              @davidclark13
                              Hi There
                              We did a rivet crop in a recent issue of Model Engineers’ Workshop.
                              Don’t think it was Model Engineer but could have been.
                              regards David
                              #80904
                              Brian Price
                                @brianprice19431
                                Posted by mgj on 31/12/2011 09:38:40:
                                Hi Chris
                                If you have a number to do you could make up a piece of scrap plate to the required thickness put a suitable hole in it and then use it as a cutting filling jig.
                                #80911
                                  A shearing action works well. Either drill a hole in some plate the thickness of which is the length you require, poke rivit into hole and a sharp coal chisel will chop it to length or you can make a pivoted blade to do the same job.
                                  All the copper rivits on my Fowler were done with side cutters, teh steel/iron ones sawn. On the larger ones for your next project you could make a jig to hold say 4 at a time and do them with a bandsaw, there is a pic somewhere on TT of it being done.
                                  J
                                  #80912
                                  mgj
                                    @mgj
                                    I thought it would come to that. The only problem with the jig (sawing) is that one has to lock the rivets, or they will rotate (I guess) under the saw?
                                    Might come to something like sawing roughly and a burst with an angle grinder and sanding disc for length? Or some grub screws.
                                    Food for thought – thanks.
                                    #80914
                                    Terryd
                                      @terryd72465
                                      Hi MGJ,
                                      As Jason and Brian suggested, a piece of plate of suitable thickness with a reasonably accurate hole and a good sharp cold chisel is one of the best solutions. The chisel must be really sharp though. There was an article in the ME a few issues ago which showed the method. If you need longer rivets use the same hole and put a suitable washer under the head for packing or on top as a chisel guide.
                                      If you haven’t plate of the correct thickness just get a thicker piece than is required and counterbore the bottom for the head of the rivet. You can get different lengths by using several rivet holes in the same plate and adjusting the depth of the counterbores.
                                      Terry
                                      #80915
                                        ’tis what you need
                                        J
                                        #80916
                                        Terryd
                                          @terryd72465
                                          Hi MGJ,
                                          I just found the article I was referring to and having read the whole article it is well worth reading. It is in issue 4412 of ME by Geoff Holland P346 onwards (“Fairlie Complex”). The explanation of riveting (in both senses of the word) is on p 347 and also has a good explanation of how to make the rivet snap (dolly) and set (‘drawing up punch’ in ‘Geoff speak’).
                                          By the way Jason,  Geoff also mentions 1.6 times diameter as extra length needed for  head, he must have read the same text book as myself, but I’ll go with your suggestion.
                                          Edit:
                                          Hi Jason, I have just found my original source of the 1.6 x diameter formula.  It is in K.N. Harris’ book “Model Boilers & Boilermaking” published by MAP in1967 which was considered the model boilermakers bible when I bought it originally as an apprentice in ’68.
                                          Terry
                                          Edited By Terryd on 31/12/2011 13:56:33
                                          #80917
                                          Brian Price
                                            @brianprice19431
                                            Posted by mgj on 31/12/2011 12:40:12:
                                            Cut a long thin slot in line with the hole with a hacksaw and then when you clamp it in the vice it will grip the rivet.
                                            #80918
                                            michael howarth 1
                                              @michaelhowarth1
                                              A gentleman called A. Mellor described an easily made “Hand Rivet Squeezer” in ME 15th May 1987 and a smaller version for riveting the wheels (awkward) of the Minnie traction engine in ME 6th May 1988. I have made both of these tools and they make a very good and easy job of riveting and forming perfect heads on1/16″ and 3/32″ rivets. I have not tried them on larger sizes. If anyone is interested in this tool, I would be quite happy to forward the articles by e mail.
                                              Mick
                                              #80921
                                              mgj
                                                @mgj
                                                Thank you Jason – tis exactly what I need – and shall make.
                                                Tery – yes I can see the advantages of the chisel for smaller/copper rivets, but as indicated, I was thinking more on the lines of 3/16 and 1/4 rivets for TE wheels.
                                                Rivet squeezers are excellent tools too, and making one would be good because the commercial ones are expensive. However there comes a point where size, as they say, starts to matter. The 5″ loco boys are at one level in the riveting stakes, and possibly in the same or similar pool as the 3″ TE gents, but even there I was dealing with a lot of 1/8 iron rivets on the strakes. Once you go up to the 4″ engines, then, even for a smaller engine, it becomes a more serious problem.
                                                I have seen a thing like a rivet squeezer which did an excellent job for dummy rivets. I suppose you’d call it a dimpler, but the fake heads looked very convincing.
                                                #80929
                                                Sub Mandrel
                                                  @submandrel
                                                  Side cutters are gettinga bad press for cutting rivets, but if you take an economy pair and grind the bottom face flat then you should be able to cut rivets straight across with them.
                                                  You can buy cutter like this for cutting electrical wires close to a surface, I have a pair but they haven’t got the cojons for rivets.
                                                  Terryd
                                                    @terryd72465
                                                    Hi mgj,
                                                    A good sharp 8″ cold chisel will easily cut a soft iron 3/16 rivet cleanly and quickly with one blow from a16 oz hammer. Have never tried a 1/4 ” but I wouldn’t expect much of a problem and done properly it gives a clean distortion free cut.. Even 14 year olds could manage it with a bit of practice. It is more about technique than strength.
                                                    But hey, why try a simple, inexpensive and elegant solution when we can devise a nice complicated machine(preferably German and expensive ) to do the job, much more satisfying, we are engineers after all.
                                                    Happy new year to all,
                                                    Terry
                                                    Edited By Terryd on 01/01/2012 04:25:51
                                                    #80945
                                                    Springbok
                                                      @springbok
                                                      I bought a rivet trimmer from Arrand some years ago saves a fantastic amount of time also crops bolts etc, It goes in the vice put your rivit in the correct hole turn vice handle and bingo one trimmed rivet. Will post a pic of it as they do not have a web site, they are a very old fashioned company and still make tools to the spec that we all were used to years ago.
                                                      Happy and prosperous new year to all
                                                      Bob.
