Yes, I'm thinking a bit of gentle heat required, if the mast was ally then no problem, get it nice and warm and it should almost fall out but will need to research the CoTE of CF tube.
edit :- a brief google suggests the CoTE of CF tube is as near to zero as makes no difference. Heat may affect the bond between the CF tube and the nylon plug (if any) but it isn't going to help release an interference fit.
I'm getting closer to drilling it out and making a new on by the day….
Any suggestions WRT turning tools for turning Acetal plastic (apparently absorbs less moisture than nylon, is harder and nicer to machine, I'm thinking sharp HSS will be better than carbide, I have some cheap Chinese carbide insert tools which work well enough for me on ally and steel but are useless on plastic). And a cobbled together method of machining a tenon on the end of a piece of round bar using only a lathe (with no milling attachments)? I could probably do the latter with a hacksaw but it seems wrong not to at least attempt a 'proper job'.
FWIW accuracy required probably +- ¼ mm will be close enough and finish only needs to be 'ok'.
Edited By Sam Spoons on 22/05/2020 16:18:11
