Well now it's 2017 and having started 2016 by fitting a VFD to my mill now I want to do the same on the lathe. To do this I need to get the old motor off, and the first obstacle is getting the pulley off the motor. This is made difficult because the allen set screw locking it on is (a) threadlocked and (b) can't easily be accessed because the belt guard has a raised lip that stops you getting straight access for a key. I could try a ball nosed key, but given that the screw is threadlocked, if this fails and knackers the hex hole then the job gets even harder!
I could probably file a recess in the aforesaid lip to clear a key, but before I do this has anyone done this job and can suggest an easier approach that I might be missing? (And by the way you have to get the pulley off first, as it won't go through the 'ole in the belt guard that the motor shaft sticks through. Ergonomic this design ain't!)
Thanks!
