Recommissioning lathe size of hole to cut for belt
Home Forums Beginners questions Recommissioning lathe size of hole to cut for belt
Viewing 8 posts - 126 through 133 (of 133 total)
  • #245343
    Hopper
      @hopper
      Posted by Martin Newbold on 03/07/2016 19:58:03:
      … it was apparant th elathe has no auto stops be ware so you dont break a gear pin
      ISTR there were a couple of threads on here recently about Drummonds found fitted with homemade stops that tripped that handlever that pokes out through the bed on your early model. Consisted of a threaded rod attached to the carriage with a moveable piece on it that tripped a lever mounted on the side of the bed and moved that handle. if you do a site search for Drummond you should find it.
      It's a very handy thing to have – standard fitting on my M-type – but can't be used for screwcutting unless you mark the change gears as well so as to re-engage in the one right position. Very nice for cutting feed on long jobs though, or when working dangerously close to a shoulder or the chuck.
      Martin Newbold
        @martinnewbold
        Hi Hopper , do you have any links please
        #245561
        bodge
          @bodge
          Hi Martin, I think the thread Hoppers referring to was titled Drummond oddities , you may remember it. I usually read most threads to do with these old flat bed Drummonds and thats the only thread ive seen with pics of an auto knock off feature . For what its worth as regards to speed, a top speed of 600ishrpm and a low speed of about 100 rpm,if you dont get the low speed down to 120rpm or less its going to be a bit of a problem when you want to use it with the back gear engaged , as in screw cutting………….b
          #245568
            Posted by bodge on 05/07/2016 20:17:58:
            dont know … Hopefully not … That was one of Martin's threads.
            bodge
              @bodge
              Yes i know, but he did ask ! oops !! Sorry Martin.
              Michael many happy returns on your recent birthday and pleased to hear your recovery is going well. Best regards………bodge
              #245581
                blush … P.M. sent to you, bodge
                bodge
                  @bodge
                  To any moderator, Martin has more than one post running for this lathe saga, would it be possible to get them combined so they all appear under one heading ( so we dont have cross refference to other threads he has posted ) as it makes it difficult to see what advise has already been given…………..b        correct speeds are given, my first post this page. by low speed  i mean direct not through back gear, i think we are having trouble with terms used used to convey the correct information………b
                  Edited By bodge on 11/07/2016 22:02
                  Edited By bodge on 11/07/2016 22:25:11
                  #260027
                  Martin Newbold
                    @martinnewbold
                    The tumbler is working brilliantly am really pleased with it. I am still running low speed at present and have not had time to remount gears
