Reaming cast iron
Reaming cast iron
Home Forums Beginners questions Reaming cast iron
  • #8566
    not done it yet
      @notdoneityet
      Thinking here of valve guides
      #284213
      not done it yet
        @notdoneityet
        When reaming cast iron, do you lubricate (further) or not? Oil, flood, cutting, tallow/graphite … anything else?
        Topic came up elsewhere. 'ONLY dry' was stipulated, but I was thinking more like often not necessary but still optional. I would use oil, but willing to learn!
        #284214
        Chris Evans 6
          @chrisevans6
          Always dry for me, it is deemed to be self lubricating.
          #284217
          Bob Rodgerson
            @bobrodgerson97362
            No Lubrication required. I think if you did use oil it would make a right mess to clean off the reamer.
            #284219
              Same as Chris, I've done it dry in all the cylinder heads I have machined
              #284221
              Brian Oldford
                @brianoldford70365
                Dry
                #284229
                Alan Wilkinson 1
                  @alanwilkinson1
                  using oil makes the reamer cut tight but gives a good finish
                  #284391
                  mechman48
                    @mechman48
                    Dry, oil + cast iron dust = grinding paste sad
                    George.
                    #284428
                    Ex contributor
                      @mgnbuk
                      Rocol RTD* liquid used for parallel & taper pin reamers into machine tool castings where I last worked.
                      Nigel B
                      * Reaming Tapping Drilling
                      #284445
                      not done it yet
                        @notdoneityet
                        Thanks for the replies.
                        Yes, I machine CI dry for almost all operations due to the graphite content (as I indicated in my OP) . The only time I use (extra) lube is thread cutting, mainly because the tool catches the 'grinding paste', particularly in blind holes – thus minimising dust into the atmosphere (if needed to be blown out). It was only for the purpose of reaming, not general machining (including boring) that I was asking about, as there is such minimal material removed.
                        Removing oil from a tap is easy enough, so I would anticipate no paricular problem with a reamer. Solvent for the oil or detergent in an ultrasonic cleaner easily suffices, if total clealiness is required.
                        Thanx to Alan and Nigel B for the confirmation that, while not necessarily rrequired, oil or cutting fluid can be appropriate.
