Qualters & Smith QSH-6 hacksaw restoration
Home › Forums › Manual machine tools › Qualters & Smith QSH-6 hacksaw restoration
  • #298826
    Andrew Lutley
      @andrewlutley12148
      -I'm part way through restoring a Qualters & Smith QSH-6 hacksaw which I bought at auction a while ago. A couple of questions:
      1. I have removed the Bow from the Bowslide and filled the Oil reservoir with oil, but the oil is not getting through to the Bow runners. I have temporarily removed the two felt pads in the Bowslide through which the oil is supposed to seep down. This exposes a small cylindrical chamber, in which each pad sits, with a small cylindrical hole leading backwards out of the top which looks as though it ought to feed direct to the reservoir. However, poking a length of wire into the hole does not get far, either because the hole has a bend or is blocked. Blowing into the top of the reservoir filler plug hole, the air seems to be getting out somewhere, but the oil is not flowing through. Does anyone have any ideas how I might be able to clear the blockage?
      2. There are several grease nipples which have a thread diameter of about 10mm. Can someone help me with the correct imperial size?
      I have the Q&S Instruction Manual, but can't find the answers to these questions.
      #12977
      Andrew Lutley
        @andrewlutley12148
        #298835
        Ady1
          @ady1
          I cleared the gungy/hard grease out of my shaper oilpoints by using an empty grease gun and pumping air through
          #298837
          Andrew Lutley
            @andrewlutley12148
            Good idea, thanks. As soon as it stops raining here ….
            #298852
            Andrew Lutley
              @andrewlutley12148
              I tried an airline, but it was difficult to get a seal as the oilway comes in at an angle to the felt plug retaining hole.
              I then tried inserting some steel rod into the oilway and tapping it with a hammer. That has cleared the blockage on both sides and I now have a steady stream of oil coming through. Next job is to make some replacement felt plugs!
              #298881
              clogs
                @clogs
                Andrew,
                they could be if ur lucky 3/8 unf and or 3/8 bsf….prob to old for the metric fine…find an old bolt and try it for size…..or get a set of thread gauges only a few quid…the cheap ones usually go unto 1/2"imp-15mm metric….be lost without mine……..Clogs…
                #298912
                Steamer1915
                  @steamer1915
                  Could the grease nipples be 1/8" BSP? That has a OD of 0.383"
                  Steve.
                  #298964
                  Andrew Lutley
                    @andrewlutley12148
                    Thanks for the suggestions re imperial sizes for grease nipples. I have ordered some 3/8" (not sure if they are unf or BSF and 1/8" BSP. When I get a fit, I will post the answer!
