Propane Or LPG powered instead of coal?
Home Forums Locomotives Propane Or LPG powered instead of coal?
  • #207125
    Brandon Thorn
      @brandonthorn58894
      I know this defeats the purpose of the whole live steam experience but I was wondering if anyone uses propane instead of coal? If so, what kind of results are you seeing?
      Are there any companies selling burner kits for locos?
      Brandon Thorn
        @brandonthorn58894
        #207127
          Burn the heretic!
          LBSC designed an oil-fired loco called Petrolea.
          Simon Collier
            @simoncollier74340
            They use propane a lot in the US. I was told they are not allowed to burn coal in California. Try some US web sites. Personally, I think it utterly defeats the purpose.
            #207130
            Bazyle
              @bazyle
              Remember your old cowboy films? Most times the outlaws were clambering across a tender full of wood not coal so if you are running a Virginia you shouldn't be using coal anyway. Definitely everyone was using propane when I visited Los Angeles Live Steamers.
              #207142
              will hawkes
                @willhawkes78155
                hi try looking up the steam boat association,,a lot of the boilers used are gas or oil fired,and they have all of the info on how they work and construction, myself use a simpson strickland quadruple expansion engine and a fire tube boiler , but that is on a 29ft launch,
                #207157
                KWIL
                  @kwil
                  Train Mountain, (USA) they all use LPG even hauling a LPG fright wagon as the track length and terrain is so vast. Designs for burners are about as well to make your own.
                  #207175
                  duncan webster 1
                    @duncanwebster1
                    There was an article many years ago in ME about making a burner for a 5"g Metro, it seemd to work quite successfully. No doubr someone will find the exact issue number
                    #207199
                    Brandon Thorn
                      @brandonthorn58894
                      Thank you all for your quick replies! I understand that steaming with LPG defeats the whole aesthetics of the hobby.
                      However, all of my vehicles run on LPG, even my lawn mower and strimmer. So I figure why not convert one of my little locos to run on the "going Green Gas" too keeping up with the pattern. I have five locos, one of which is the 5" G Metro, If i can find the article that duncan was talking about, I would like to try it on LPG.
                      Please let me know If anyone has any further information on where I may be able to find this article?
                      #207200
                        Posted by Brandon Thorn on 09/10/2015 15:09:45:
                        Brandon,
                        I would be very interested to learn about your LPG strimmer.
                        Ady1
                          @ady1
                          ME 4119
                          184,4119,531,Boiler,LPG Regulation for a Model Boiler,,Derek Oxley,"Introduction, the modification, disassembly,
                          accessories, parts to be made, modified or acquired, assembly, testing, initial setting of regulator, subsequent ignition and start procedure, regulator mounting frames, afternote: material costs"
                          190,4188,141,Locomotive,Gas Firing for Miniature Locomotives. Experiments with LPG,,C.H.Jones,"Coal fired engine,
                          alternative fuels, principle of gas firing, standard gas burner limitations, burners suitable for steam boilers, developing
                          burning, practical measurements of burner operation, driver gas regulator, operation and safety, adapting"
                          There are a few articles around, this index is invaluable
                          Edited By Ady1 on 09/10/2015 16:07:06
                          #207207
                          duncan webster 1
                            @duncanwebster1
                          Home Forums Locomotives Topics
