Hi Ron, referring to Julians original post, if steam was getting to the cylinders via a leaking regulator it would have to either go through a cylinder inlet (unlikely in mid gear, but a small possibility) or through a poorly seating exhaust valve.
Either way, there would be a possibility of some piston movement.
But as you say it runs fine on air, and had a boiler test recently, I would still suggest that the blower was opened too early and too wide.
That would rob a lot of steam from the boiler straight up the exhaust.
I normally start my boilers with kindling and a little coal, and even throttle the electric blower back so as not to produce a massive draught, you shouldn't really try to raise steam too quickly.
Then with about 30 psi on the gauge I remove the electric blower and just crack the steam blower open while adding more coal.
Have fun
Lofty
