Prescription Safety Glasses
Home Forums General Questions Prescription Safety Glasses
  • #132772
    michael cole
      @michaelcole91146
      Does anyone here use prescription safety glasses? I am now getting slightly longsighted ( need glasses for close up work) and I am considering buying a pair. What would be a typical (cheap) price and what should I be asking for? These are intended for wear at the lathe with a good clear chuck guard. For grinding work I intend to still wear my normall safety glasses.
      michael cole
        @michaelcole91146
        #132777
        mechman48
          @mechman48
          I use them, Bi-focal, but they were supplied by a previous employer so can't say what I would have paid for them, but I could hazard a guestimate of around £80 (employers get a substantial discount) from the last price I recall. I am going to get mine reglazed during the next couple of weeks as they need updating now so could let you know later. Pop into your local opticians & ask, they all do them on request.
          George
          Edited By mechman48 on 15/10/2013 22:07:46
          #132787
          Metalhacker
            @metalhacker
            I have prescription varifocal safety glasses. Not cheap at around £150, but my eyes are valuable particularly as only one works. Very much worth it IMHO.
            BW
            Andries
            #132788
            Stovepipe
              @stovepipe
              Wouldn't safety GOGGLES be far more useful and safer ?
              Dennis
              #132805
              RichardS
                @richards31161
                Full face visor e.g. Machinemart 040433610, Vitrex 334100 Safety Shield. Much cheaper than prescription safety glasses and shields your whole face.
                Glasses and goggles don't really mix anyway, I find the goggles tend to push the glasses away from their optimum position.
                #132807
                HomeUse
                  @homeuse
                  Just had pair from "Should have gone to" (British TV Add) – Cost £68 – Free Eye test – Ready in 14 days – Spec :- Clear glass upper area for long,normal distance and perception in lower area – needed getting used to not looking thro' top and bottom at the same time – No Problems
                  #132808
                  Trevorh
                    @trevorh
                    Most one stop shops supply Over Safety Glasses that fit over and around existing glasses I have to use them when I go into various factories try Arco and the like
                    #132809
                    John C
                      @johnc47954
                      I use bifocal safety glasses available from the likes of Amazon – do a search for 'Bifocal Safety Glasses'. I find them very good and not too pricey.
                      Edited as URL did not condense to 'Link'
                      Edited By John Corden on 16/10/2013 09:37:26
                      #132813
                      Mark C
                        @markc
                        I bought some "Infield terminator" that take inserts – they are very comfortable and I don't have to worry about the prescription part getting damaged as you can buy the outer bit separately. I get mine from the local builders (I have an account which helps) but you can look here **LINK** and you will find them a bit down the page on the left. They also wrap around preventing anything getting down the sides. I only have prescription for close work but I would think you can have them in every prescription you want. Price for me was £45 if I recall. You have to get your prescription from the opticians (free, it's yours anyway) and they also want to know the distance between your pupils which the optician will also tell you.
                        Mark
                        #132816
                        The Merry Miller
                          @themerrymiller
                          The last prescription safety glasses I had, about two years ago, were from Boots Opticians.
                          They were single vision and made by "Parmelee" ( see their website )
                          Boots will show you what they do, there's quite a range for different occupations,
                          Mine cost £35 at the time, it wasn't a special offer either.
                          Len. P.
                          #132817
                          Rik Shaw
                            @rikshaw
                            My last job in the engineering trade was spent in the tool and cutter department. Both my work mate and I found it impossible to do close work wearing safety goggles as we could not see detail properly – trying to wear them for prolonged periods whilst regrinding say a batch of 1/4" ball end cutters was torture on the eyeballs with headaches common. No matter how well you treated them they scratched easily and after only a short period of use became cloudy following frequent cleaning.
                            After many complaints the company relented and sent us to the optician for sight tests and we were both prescribed safety spectacles (the ones with the Perspex side guards). No magnification was necessary as both of us had A1 vision. These proved to be excellent and being resistant to scratching were well up for the job in hand.
                            Rik
                            #132834
                            michael cole
                              @michaelcole91146
                              Thanks for the replys. As I said I am looking only for safety glasses. I already have and wear googles and a full face when required. My company uses S***savers for our VDU eyesight test, But I shall now go and have a look at Boots and online
                              #132837
                              mechman48
                                @mechman48
                                Update:
                                Just called in to my opticians today 'should have gone to …', HSE & Insurance Co's will not allow reglazing of safety specs, ordered new pair, picked out personal choice frame (light metal) with ultra large Bifocal section for close work (non standard so extra cost), scratch resistant coating, polycarbonate side shields…£119.
                                George
