Please help with fitting a Myford Tri Leva
Home Forums Manual machine tools Please help with fitting a Myford Tri Leva
  • #13073
    choochoo_baloo
      @choochoo_baloo
      choochoo_baloo
        @choochoo_baloo
        A bought a Myford Tri Leva attachment for my ML7 a while back, and got around to start fitting in today.
        I assumed it would be 'obvious' and I could work it out from the pile of bits. Turns out this was naive!!
        I've read the half page entry on installation in the Myford ML7 manual, but it's not very thorough (at least not for a semi newcomer).
        Therefore I'm hoping a kind fellow Tri Leva owner can talk me through the full installation process; beginning from removal of the existing headstock bits.
        Thanks in advance.
        #337565
        choochoo_baloo
          @choochoo_baloo
          bump
          #337571
          Jim Cahill
            @jimcahill55556
            I had a Trileva ML7 many years ago and found the attachment a complete nuisance. I took two of the belts off and fitted an electronic speed control. I used the one active lever as a clutch. Thereafter it was a super lathe within its limitations. To this day I have never figured out why the previous owner hadn't put the cost of the trileva attachment towards a Super 7 instead.
            #337573
            Jim Cahill
              @jimcahill55556
              I just noticed there is a Raglan 5" for sale. I has a variator for speed control. I can thoroughly recommend the Raglan. You should be quids in if you sell your Myford.
              #337576
              not done it yet
                @notdoneityet
                I have spoken with the vendor (of the Raglan 5” offered in the forum advert section). It is most certainly a 5” model, but is either a very early example, or (more likely) a cheaper ‘ schools’ variant of the normal 5”, in that it has the same ( well, very similar) carriage to the Little John. The cross slide is likely improved and it does have the larger diameter lead screw. I changed from a LJ to the 5” for the advantages of the better designed, and somewhat superior, apron.
                However, I agree with Jim. You get a far superior lathe compared to the average myford. I am, of course, not biased in any way whatsoever smiley.
                Extra bits of info are that while the change-wheel LJs were convertible to QCGB, the 5” models, without, are not so easily converted. These lathes will have the wider (stronger) drive train gears, compared to the earlier LJ Mkll lathes, along with the 5” adjuster (easier and better than the multi position banjo of the later LJs).
                At 3 1/2 cwt, and probably a bit, they are more robust than a myford, but I have loade several in and out of my Citroen Saxo without too much hassle – and without any assistance on occasions. The stand would likely need a second trip for my Saxo as I think it might be overweight for the roof rack!
                Kevan is open to offers – and I am sure it is a genuine lathe in good mechanical order, even if it may need a motor repair or change.
                #337577
                Robbo
                  @robbo
                  To get back to the original question:
                  If you have a look at the pictures of a partially assembled Tri-Leva on lathes.co.uk here **LINK** together with the parts diagram at section S of the ML7 manual it might give you an idea of how to proceed
                  Edited By Robbo on 20/01/2018 14:56:28
                  #337582
                  daveb
                    @daveb17630
                    You have to undo the headstock screws, these are usually very tight. Fit the lower belt guide, remove spindle and fit belts, assemble top end and fit belts to countershaft pulley. Adjust belts one at a time until they are just tight enough, if they are too tight the roller frame will distort and cause the belt to ride off and jam. Some patience is required to get it right, I persevered and was happy very with the outcome. There is enough effort involved for many people to look at alternatives, but they would probably prefer a Super7 anyway.
                    Daveb
                    #337595
                    Cornish Jack
                      @cornishjack
                      One point worth noting – make sure that the 3 belts are matching. I did a belt change on mine many years ago … twice!! blush I eventually got the message and bought a complete new SET!
                      rgds
                      Bill
                      P S – just to add, it is a most useful BASIC accessory (3 levers locked to change chucks etc., and instant speed change 'on the run' ) – if you add a VFD it becomes superb.
                      B
                      Edited By Cornish Jack on 20/01/2018 18:04:14
                      Edited By Cornish Jack on 20/01/2018 18:04:53
                      #337624
                      choochoo_baloo
                        @choochoo_baloo
                        Posted by daveb on 20/01/2018 15:28:54:
                        Daveb
                        Thanks for the specific instructions Dave. Do you mind me PM'ing you if I get stuck along the way?
                        #337625
                        choochoo_baloo
                          @choochoo_baloo
                          Posted by Cornish Jack on 20/01/2018 18:00:47:
                          rgds
                          Bill
                          B
                          Thanks Bill.
                          The supplied trinity of belts do seem a bit ragged – where would you suggest I buy a matched replacement set. Don't think new Myford sell them.
                          #337632
                          Hopper
                            @hopper
                            Posted by choochoo_baloo on 20/01/2018 22:56:13:
                            rgds
                            Bill
                            B
                            Thanks Bill.
                            Any industrial supply house that sells bearings and belts and the like should be able to supply a matched set of three belts if you give them the belt number, or dimensions. Make sure you ask for a proper matched set of three belts, designed to run on three-groove pulleys, or they might just give you three single belts out of the box.
                            #337634
                            thaiguzzi
                              @thaiguzzi
                              Nice Raglan 5" on the Lathes.co.uk website. Gearbox, well tooled, clean, decent price.
                              Posted by not done it yet on 20/01/2018 14:39:19:
                              #337665
                              Cornish Jack
                                @cornishjack
                                "The supplied trinity of belts do seem a bit ragged – where would you suggest I buy a matched replacement set. Don't think new Myford sell them.
                                Sorry, CCB – it was a looooong time ago and cannot remember source. The other point to bear in mind, of course, is that the external surface is important 'cos the engaging jockey wheels run on them!!
                                rgds
                                Bill
                                #337671
                                daveb
                                  @daveb17630
                                  Posted by choochoo_baloo on 20/01/2018 22:54:15:
                                  You're welcome, I will help if I can. Daveb
                                  #337675
                                  paul1
                                    @paul1
                                    CCB
                                    I fitted a Tri-Leva to my ML7 a few years ago. So far as I know the belts are standard Myford headstock drive belts. That's what I use anyway. I got mine from lathespares.co.uk. Hope this helps.
                                    Paul
                                    #337681
                                    Muzzer
                                      @muzzer
                                      I've bought a few belts from beltingonline.com The official belt shpe and length must be well known and easy to find out. Worth checking the prices against. It looks as if they sell Fenner (India) belts.
                                      The belts I bought last week said they were "matched" according to the info printed on them. As they were all different sizes, I assume it is implying that belts of the same size are suitable for running on multi-groove pulleys.
                                      Murray
                                      #341413
                                      choochoo_baloo
                                        @choochoo_baloo
                                        I have almost finished fitting the Tri Leva. Unfortunately one piece is missing: "S59 Link". Fortunately it’ll be simple to make from scratch.
                                        Therefore can any Tri Leva owners please post the dimensions of the part "S59 Link" which I've circled in red from scans of the ML7 manual:
                                        Is mild steel plate, subsequently chemically blackened, a good material choice?
                                        Thanks in advance.
                                        Edited By choochoo_baloo on 14/02/2018 00:12:31
                                        #341637
                                        Meunier
                                          @meunier
                                          Just done a rough measure, most with digi caliper, couple with 6in rule.
                                          o/a length 73mm, width 19mm, 2.2mm thick material, adj slot 24mm long starting 6.8mm from L/H end, hole at R/H end about 10mm from end (best guess I could get with a slim ruler and MK1 eyeball )
                                          Not the most accessible piece to measure so some minor parallax error on the caliper jaws inevitable but you have enough length of adj slot to compensate !
                                          Your material choice sounds good
                                          HTH
                                          DaveD
                                          #341643
                                            I love this forum…
                                            Question: How do I fit this tri-leva attachment I bought?
                                            Answer: Sell your lathe and the attachment and buy a new one.
                                            crying
                                            Billy Bean
                                              @billybean67480
                                              Neil – I like that answer.
                                              For spare parts , technical advice, drawings, etc, you will find Myford extremely helpful.
                                              myfordinfo@aol.com is the e-mail or 01422-885766
                                              BB
                                              #341675
                                              daveb
                                                @daveb17630
                                                Posted by Neil Wyatt on 15/02/2018 15:58:02:
                                                I love this forum…
                                                crying
                                                This is the place to come to for good advice. smile d
                                                #341792
                                                choochoo_baloo
                                                  @choochoo_baloo
                                                  Posted by Meunier on 15/02/2018 15:05:54:
                                                  HTH
                                                  DaveD
                                                  Brilliant, thanks a lot Dave.
                                                  #341824
                                                  Meunier
                                                    @meunier
                                                    You are welcome, CC_B, I get a lot from this forum, happy to be able to give a little back.
                                                    DaveD
