Posted by Russell Eberhardt on 05/01/2015 11:26:16:
Posted by Ian L2 on 04/01/2015 18:14:14:
Vibrates and sounds clunky but that might be the belts as one is incorrect size and both very old (new one ordered) and appears to run eccentric to the eye.
Tried to get Dti on the register behind chick but Dti jumps like a good-den which is not surprising as having close look, the surface is bit damaged. I had
drop M. T in spindle and Dti on that,
M.T rusty. cleaned with wet n dry tried again, M.T still does not feel quite right. suspect inside spindle not clean so need to get something to clean inside Spindle And a New M.T. Will have another go then.
It sounds as if you are getting into a bit of a pickle. You need to separate the different possibilities for the DTI jumping around.
To check the spindle rotate it by hand not under power. That will eliminate any vibration from the motor or belts.
When I first got my Atlas I had a fair amount of vibration until I corrected the following:
- Replaced the old hardened belts with new ones
- Set the correct preload on the bearings
- Replaced the countershaft bearings
- and finally replaced the motor with a three phase motor and VFD
Russell.
Hi Russell
You mentioned "replacing the countershaft bearings" I have the atlas part numbers as 9-108 and 9-109, Do you still have the old ones? just wondered if there is any ref numbers so I can try the bearing shop that we use at work to see if they are common easy to get bearings. I have new belts and without spindle belt fitted there is quite a lot of clunking from countershaft.
Thanks
