Piston material for S50 engine
Home › Forums › General Questions › Piston material for S50 engine
  • #21936
    The Merry Miller
      @themerrymiller
      #75299
      The Merry Miller
        @themerrymiller
        This question has probably been asked many times but search as I might I can’t find answers on this forum.
        The raw material supplied in the kit for the Stuart S50 engine is supposed to be brass but it has a slight coloured sheen on the outer face which leads me to believe that it may be phosphor bronze.
        The question is what is preferable for a piston operating inside a cast iron cylinder, brass or phosphor bronze?
        I’ll most probably be running on compressed air until I have built a boiler for it.
        Len. P.
        #75300
        Bogstandard
          @bogstandard
          It wouldn’t really matter in your situation, but the bronze would be a little better in the wear stakes.
          You might find a little difference in the machining, but I would expect Stuarts to supply a free cutting bronze anyway, so just go ahead and use it, the sky won’t fall on your head.
