Parting off on a mini lathe
Home Forums Beginners questions Parting off on a mini lathe
Viewing 8 posts - 26 through 33 (of 33 total)
  • #815086
    Dell
      @dell
      I have a Myford 10 & had problems parting but now I have rear parting tool HSS parting tool upside down swarf falls away ( couldn’t run lathe in reverse as screw on chuck ) I don’t have problems but everything needs to be as ridged as possible .
      Richard Simpson
        @richardsimpson88330
        Just a question ladies and gents.
        I see a lot of references in this thread to rear mounted tool posts.  Reading the reasoning behind this I can see the advantage but what justifies using a rear mounted tool post over simply turning the tool upside down in the normal tool post and rotating the job clockwise instead of anti clockwise?
        #815097
          Most using the read toolpost will have Myfords or similar where the chuck screws onto the spindle nose. If you run them backwards the chuck can screw itself off!!
          #815101
          Bazyle
            @bazyle
            The main reason for the rear toolpost is the way most amateur lathe saddles are/were made with nothing to stop the rear of the saddle lifting off the bed, or if a plate was fitted eg Boxford it probably wasn’t set tight. So if the tool catches it lifts and when you examine the geometry that relieves the cut. The other reason is some people are obsessed with the fear of the chuck unscrewing when run in reverse.
            #815107
              On Richard Simpson Said:
              … what justifies using a rear mounted tool post over simply turning the tool upside down in the normal tool post and rotating the job clockwise instead of anti clockwise?
              Whilst running upside down in reverse is an advantage, rigidity is the main reason for using a rear tool-post.
              Comparison!
              My front tool-post is a towering multi-jointed edifice.  I’d describe it as spindly rather than solid, and it’s height causes it to increase forces by acting as a lever.  All front tool-posts are bendy, especially those on small lathes.
              When cutting, Newton’s third law applies: ‘when two bodies interact, they apply forces to one another that are equal in magnitude and opposite in direction.‘  A front-tool post’s ability to resist ‘opposite in direction’ forces is limited by how much metal is in it, the height,  the joints, and the route taken by reaction forces to ground.
              DSC06917
              In contrast rear tool-posts are a hefty solid block of metal firmly bolted to the saddle.  They are much stiffer than a conventional front tool-post.  Stubby with only two joints: the slot for the cutter, and where it joint the saddle.  Leverage is minimised too: cutting forces are taken almost directly straight down into the saddle.  It’s instructive to trace route taken by forces grounding through a front-tool post; it’s long and twisty – not ideal.
              DSC06918
              As front tool-posts go, though inferior to a rear type, the 4-way is fairly solid.  As QCTP tend to be more spindly with extra leverage through the tool-holders, they are often less rigid.  Therefore I suggest beginners think twice before rushing to fit them.  Ask what’s more valuable in your workshop – is it rigidity or the ability to swap HSS tools quickly?
              John Haine
                @johnhaine32865
                What revolutionised parting for me was to start doing it at higher speed using power cross feed.  Higher speed gives lower chip load per rev and better cutting action by the tool, PXF is smoother and isn’t prone to “stutter” like humans.  I use a insert type parting tool in a QC toolholder (Dickson type).  My S7 has a custom toolpost without topslide and the feed is stepper powered by the CNC controller.
                #815120
                  Front QCTP works for me even on a “spindly” cross slide
                  70mm cast iron parting a 1.5mm thick disc, part held by approx 15mm dia chucking spigot
                  DSC02442
                  200mm dia x 25mm thick wall steel tube with 1.5mm HSS. I did saw the last 0.75mm rather than have the ring drop on the bed.
                  20230112_145504
                  #815134
                  Martin Kyte
                    @martinkyte99762
                    When cutting, Newton’s third law applies: ‘when two bodies interact, they apply forces to one another that are equal in magnitude and opposite in direction.‘  A front-tool post’s ability to resist ‘opposite in direction’forces is limited by how much metal is in it, the height,  the joints, and the route taken by reaction forces to ground.
                    Not quite as simple as that with regard to tool posts. Opposite usually involves  a couple which tranfers the force opposing the cut to the front ‘foot’ of the tool post and the front shear. Relaxation of the cutting force can cause the tool to ‘nod’ forward which tends to increase the depth of cut generally causing chatter and sometimes a dig in. When the operator is tentative in approach to parting this can often happen whilst with a more robust approach everything is ‘hard back on the stops’ and well out of the danger zone. That’s my interpretation.
