Hand hacksaw with 4 blades with two outer ones upside down as spacers. Clamp plates each side of target as guides and off you go. If you are not very accurate you could then clean up with an end mill which will be less unhappy since the bulk is gone.
Slot drills are for ……………slots. End mills are only suitable for going down the end of a job, not the middle else they would be called 'middle mills'.
The 4 teeth/flutes on an endmill cannot advance straight into the face of a slab. Just try holding one up against a flat surface and you will see the difference compared to a 2 fluted item such as a drill. (for the feeble minded no I am not suggesting you can use a drill sideways on steel just because it has 2 flutes though people do do that in wood).
To let the dust out file a small gap in the outside ridge at the middle or make it in reverse with slot in door bottom.
