Painting on old galvanize
Home Forums General Questions Painting on old galvanize
Viewing 21 posts - 1 through 21 (of 21 total)
  • #27554
    Adrian 2
      @adrian2
      Adrian 2
        @adrian2
        I am considering stripping off the old paint on my up and over garage door, it comes away in ribbons revealing the old unbroken original galvanizing.
        My thoughts are, thoroughly clean galvanize, etch prime, undercoat, top coat.
        Is this the way to go? Any recommendations for best paint system welcomed.
        Thank you.
        Adrian.
        #489159
        David George 1
          @davidgeorge1
          Hi Adrian. Painting on galvanised steel is always a problem as the original paint peels of easy. What you are using is what I would use as you only do it once so do it the best way you can. You can get a two part epoxy paint to replace the traditional way but not having used it my self I couldn't recommend it.
          David
          #489163
          Thomas Cooksley
            @thomascooksley79020
            Hi Adrian, The etch primer is the key. Looks like it may not have been etch primed first time that's why it's peeling of. You may need to degrease the door before applying the etch primer. As for the top coat how about hammerite, available in several colours with a smooth or hammered finish. That's what I would do.
            Tom.
            #489164
            Martin Kyte
              @martinkyte99762
              Underseal.
              Martin
              #489168
              Paul Lousick
                @paullousick59116
                An etch primer is usually used on galvanized steel. Check with the makers instructions because some also require a normal primer over the etch prior to adding a top coat.
                The surface must be completely cleaned of any previous paint because it contains an acid which reacts with the metal. It will not adhere to paint, fillers, etc.
                2 part epoxy paint also requires priming first but if using, full PPE should be used as it is poisonous if inhaled.
                Paul.
                #489169
                Clive Foster
                  @clivefoster55965
                  White, silver or other reflective light colour is best. Garage doors get hot in the sunshine and the constant thermal movement shifts most paints in time.
                  Hammerite tends not to be terribly good as the cover coat is too thick. New fangled worse than old fangled.
                  There is/was a so called "garage door paint" from, I think, International. Brush on. Not good in my experience.
                  Were I to do a metal door again I'd be tempted to use many thin coats having had some success with this approach for difficult things in the past.
                  #489171
                    Mordant solution is the traditional treatment for galv but there are several modern primers that will work such as Zinsser's "Bullseye 1-2-3"
                    #489184
                    KWIL
                      @kwil
                      You can also use a high zinc paint over the galvanised surface ZINGA (painted on) or Zingaspray. You can then use a sealer followed by your top coat of choice.
                      #489185
                      Adrian 2
                        @adrian2
                        Thank you all for your ideas and advice, success hinges on that first coat of primer . I will gen up and make a selection.
                        Adrian.
                        #489192
                        Baz
                          @baz89810
                          Seem to remember that Hammerite do a speciality metals primer which works on galvanised, I purchased a tin before lockdown but cannot seem to find it at the moment, along with quite a few other things.
                          #489197
                          Nicholas Farr
                            @nicholasfarr14254
                            Hi, B&Q sell Special metals primer from Fortress and Hammerite, the latter being cheaper, but both pricey for their amounts. I can't vouch how good either of them are though. Special Metals Primers.
                            Regards Nick.
                            #489204
                            clogs
                              @clogs
                              when we could only get plain galv corrogated iron sheets for roofs in S.Africa, when the colour'd was needed we use to wash the panels down with brick acid (whatever that is) then wash with clean water…..
                              Beware, it was a bit stinky ………
                              no prob with adhesion after that……we did use the proper roof paint tho…
                              dont know about Fortress paints but Hammerite will never cross my threshold ever agin…..pure rubbish…..
                              actually Screwfix's hammerite is / was OK when I last used it…..
                              #489210
                              File Handle
                                @filehandle
                                Galvanized sheets generally take paint a lot better after they have weathered for some years. i assume that using acid simply speeds this up.
                                #489212
                                Pete White
                                  @petewhite15172
                                  Posted by JasonB on 04/08/2020 14:23:04:
                                  That is good stuff, makes paint stick better than "anything" to blanket !
                                  Yes I also believe, from my Landrover days, that hammerite do a primer for galv and ali.
                                  I few months ago I painted a double up a over door in a paint by "Bradite", quality stuff. I am no painter but it went on a treat, one coat of a light green over purple, no runs. Very optimistic that it will perform well. My paint brand of choice now.
                                  pete
                                  #489229
                                  Hopper
                                    @hopper
                                    Rubbing galv down with vinegar can help etch the surface to help paint stick.
                                    #489258
                                    Sam Longley 1
                                      @samlongley1
                                      Although I have not tried it myself; My painting contractor & some of the members of the yachting forums(for keels) recomend one of the Dulux weathershield products.- metalshield primer etc
                                      Edited By Sam Longley 1 on 05/08/2020 10:05:09
                                      #489259
                                      Brian Oldford
                                        @brianoldford70365
                                        T Wash is the stuff to use. Used extensively as body preparation by many heritage railways.
                                        duncan webster 1
                                          @duncanwebster1
                                          You can't get the old fashioned Hammerite any more, I never liked it anyway, easy to apply but seemed to chip easily after a few years. Unless you want the hammered look the modern stuff doesn't seem to have any advantage over Alkyd, it doesn't dry particularly quickly.
                                          #489262
                                          Swarf, Mostly!
                                            @swarfmostly
                                            Hi there, all,
                                            I don't know what process is used for the galvanised sheet steel from which garage doors etc are made. Maybe it's an electro-zinc process.
                                            I doubt that it's a hot dip process unless it is configured rather in the shape of a float glass plant.  (Long and narrow and hot in the middle! )
                                            The following is my understanding about hot-dip galvanising – I welcome correction from any members with first-hand experience. I understand that hot-dip galvanisers float a thin layer of molten palm oil on the surface of their molten zinc vat/bath. When the item is removed from the bath it gets coated with a film of palm oil on top of the zinc – it is this that makes the item difficult to paint until the weather and any passing microbes have removed it.
                                            Best regards,
                                            Swarf, Mostly!
                                            Edited By Swarf, Mostly! on 05/08/2020 10:43:00
                                            #489920
                                            Mike Woods 1
                                              @mikewoods1
                                              +1 for Zinsser Bullseye 1-2-3, followed by Zinsser AllCoat white satin exterior paint. I did my garage door 18 months ago using a small brush for the seams and fiddly bits and a small gloss roller for the rest. I was impressed by the the finish, ease of application and no messy clean up afterwards.
                                              I was dubious about using water based paint at first so did a trial on some of old and new galvanised sheet scraps. Even just 24 hours after application it was very difficult to remove by scraping, but after curing for a week or so it was nigh on impossible to remove. I guess time will tell, but so far, so good.
                                              Since then, I have started using water based paints on interior woodwork.
                                              I have no links to Zinsser, just another DIYer with a paintbrush in hand.
