One for the thinkers?
Home › Forums › Beginners questions › One for the thinkers?
Viewing 23 posts - 1 through 23 (of 23 total)
  • #173777
    nigel jones 5
      @nigeljones5
      Just musing through my bath time and asked myself this question – if all things are equal would a 1/4" diameter big end (crank pin) which was 10 thou under size knock more, less or the same as a 1 inch dia crank pin, worn to the same amount?
      #7416
      nigel jones 5
        @nigeljones5
        #173778
        fastjohnrs
          @fastjohnrs
          If they have the same amount of play I'd imagine they'd knock the same, unless the difference in weight of components has a part to play, be interesting to see what other people think
          Edited By JasonB on 28/12/2014 07:25:54
          #173779
          S.D.L.
            @s-d-l
            Posted by fastjohnrs on 27/12/2014 19:27:31:
            For any class of fit the amount of clearance or interference increases with diameter so what may be sloppy on a small shaft would be proportionally tighter on a bigger shaft.
            Steve.
            Edited By JasonB on 28/12/2014 07:25:30
            #173781
            KWIL
              @kwil
              How are you defining "knock"? Loudness or frequency of the knock? Size of the component parts will change everything.
              Edited By JasonB on 28/12/2014 07:25:07
              #173786
              Nobby
                @nobby
                No
                some body will come up with the reason
                Nobby
                #173792
                  Posted by fizzy on 27/12/2014 19:23:17:
                  So good you asked it twice ?
                  devil
                  Gary Wooding
                    @garywooding25363
                    Well, how about a 1/10" crank pin vs a 10" crank pin?
                    I reckon the 1/10" would knock a lot more than the 10".
                    #173795
                    Bazyle
                      @bazyle
                      Is "the same amount" 10 thou or the same as in % ?
                      #173796
                      FMES
                        @fmes
                        Could it be considered that the smaller crank pin would be fitted to an engine that ran at a much higher speed, the knock rate (frequency) would possibly be above the hearing range of the human ear, and therefore inaudible or masked by the equally annoying exhaust note wink
                        #173797
                        Ian P
                          @ianp
                          Which of the 'All Things' you had in mind, are equal?
                          Maybe, radial clearance, 10 thou on both sizes or maybe the same percentage diameter reduction, (or increase if the bore is worn)
                          I am sure you have touched on a very interesting subject but the problem needs to be better defined so that we don't wait until 1/4/2014 before replying.
                          I think showers are better than baths, thinking time is not as long so there is less time for the ideas to be generated
                          Ian P
                          #173802
                          nigel jones 5
                            @nigeljones5
                            Like I said, all things equal, same speed, 10 thou under size on each pin.
                            I used to shower but 18 month olds don't like them as the duck doesn't float.
                            #173804
                              Posted by fizzy on 28/12/2014 09:43:12:
                              Simple geometry; the smaller version will 'rattle' more.
                              For demonstration [rather than proof] extrapolate to even larger/smaller versions.
                              At very small sizes the fit will look "like a sausage up the Mersey Tunnel".
                              Chris Trice
                                @christrice43267
                                The smaller would knock more because the angle the crankshaft will have travelled through at the top and bottom of each stroke would be greater and there would be a higher contrast of speed in the up and down direction betweent the the point the two components stopped touching each other and the moment the clearance was taken up again.
                                #173808
                                Chris Trice
                                  @christrice43267
                                  That's assuming that the stroke and proportions of the engine were proportionally matched to the crankpin diameter  but the clearance was the same in both cases.
                                  Edited By Chris Trice on 28/12/2014 11:09:23
                                  #173816
                                  Speedy Builder5
                                    @speedybuilder5
                                    Depends upon the temperature and thickness of oil and probably Reynolds number. The larger would have more anular area to squeeze out the lubricant. – Probably
                                    BobH
                                    #173819
                                    Ian P
                                      @ianp
                                      Posted by Speedy Builder5 on 28/12/2014 13:52:02:
                                      BobH
                                      But Fizzy said all things were equal.
                                      To get equal conditions maybe the 1" diameter journal would be correspondingly narrower than the 1/4" one so that lubricant trapped in the annular area would be the same.
                                      Simplest would be to assume no lubricant at all.
                                      Ian P
                                      #173835
                                      V8Eng
                                        @v8eng
                                        I must say that I'm not sure exactly how relevant this is, but here goes anyway:
                                        I have always understood that a worn big end on an engine makes a deep rumbling noise, whilst a worn little end makes a lighter rattling type noise.
                                        Edited By V8Eng on 28/12/2014 19:39:28
                                        #173843
                                        John Stevenson 1
                                          @johnstevenson1
                                          Did you remove the coal first ?
                                          #173851
                                          V8Eng
                                            @v8eng
                                            Erratum.
                                            My last post should have read 'deep knocking noise' rather than 'rumbling' .
                                            #173858
                                            Hopper
                                              @hopper
                                              LOL. I can tell you from experience that a Harley Davidson with its 1" crankpin worn just three thou undersize will make a knock to wake the devil. NO little model engine with a 1/4" crankpin could even come close to making the same noise. A ten thou undersize crankpin on a Harley engine would be deafening.
                                              Why? Because each Harley con rod is hammering about 35 horsepower to the crankpin, compared with 3/5 of 5/8 of a gnat's whiskerpower being delivered to said 1/4" model crankpin.
                                              Apart from that, try this: Bang together two large lumps of steel weighing several pounds each and listen to the clang. Now bang together two 5/16" nuts and compare the volume of the collision.
                                              #173965
                                                So you've turned your crankpin 10 thou undersize and you want an excuse not to rebush the rod……?
                                                nigel jones 5
                                                  @nigeljones5
                                                  Hi Neil – actually no, I was honestly pondering this as described. The lead up to said muse was that I have just reduced the link pins on my 71/4 Invicta from 5/16 down to 3/16 and wondered if they would me more or less likely to knock when they become worn. Cynic !!
