O – Rings, bit of help needed
Home Forums General Questions O – Rings, bit of help needed
  • #148102
    Oompa Lumpa
      @oompalumpa34302
      So, my "Get-out-of-Jail-Free" card has expired. ie. I can't find the chap I normally call for advice with this is MIA and I suspect he left his present job and has gone elsewhere. No surprise really as he was very good. But that now leaves me with the problem that I have pretended would never arise: Which 'O' ring to use for a specific job. I throw myself at the mercy of the forum!
      The problem: I have a piston (in brass for the sake of pedantry) which measures out at 29.5mm, the Bore is 30.5mm (Chrome). Which size 'O' ring do I use to create a seal? The piston is compressing air to approx 750psi and I would normally on something this diameter use two 'O' rings one right behind the other and a nylon skirt ring for smoothness.
      I prefer to use Viton rings but now, as my contact has left, I have no reference. If someone could point me in the right direction for some specs. I would be grateful. Depth and width of groove are also quite critical.
      Thank you,
      graham.
      #23221
      Oompa Lumpa
        @oompalumpa34302
        #148105
        David Jupp
          @davidjupp51506
          James Walker web site offers a free 'O Ring Guide' covering materials, housings etc. Other manufacturers may also offer similar technical material.
          #148108
          mick
            @mick65121
            The ERIKS "O" ring calculator is very good, just select material, size etc and it does the rest, an online search for Eriks O rings, should bring it up
            #148117
            Oompa Lumpa
              @oompalumpa34302
              Took some finding but HERE is the calculator for anyone looking in future.
              graham.
              #172175
              Ian P
                @ianp
                Has anyone actually used the Eriks online calculator successfully I wonder?
                I need to design several O ring sealed joints and have just spent the last hour struggling to make sense of how it works. I am baffled as to how, once having saved a design (after registering and logging in etc) that design is reloaded to edit or print out.
                I can find no instructions in how to use the calculator but I think there may be a clue to its failings in that the features of this free design calculator include the ability to SAVE designs. However nowhere do that say it can load designs!
                I think I might be able to get the details and dimensions I want by writing down the various intermediate results and then entering them again on the keyboard when needed for the next step.
                No wonder it took you a while to find it Graham, maybe they hide the results as well.
                Ian P
                #172249
                Jon
                  @jon
                  Just tried it, seems to work.
                  What you will find is if buy three o rings from three sources to a BS standard most likely they will actually measure different.
                  So what you have inputted will change when o rings come.
                  It would be quite usable if the link provided off the shelf o ring sizes rather than input size of parts only to find nothings remotely available. For this to work would have to input actual o ring size.
                  Very rarely I draw things out and tend to either compress the o/d or expand the bore or even both. Some try to tell you to create clearance on a piston bore so floats with minimal contact on I/d of bore, the pressure creates o ring to contract and expand to create the seal.
