New website editor
New website editor
Home Forums General Questions New website editor
Viewing 25 posts - 1 through 25 (of 59 total)
  • #84819
    David Clark 13
      @davidclark13
      Hi There
      We are changing the website text editor due to Intenet Explorer not being backwards compatible.
      It is the same editor as used for personal messages so many of you will already have used it.
      If you find any problems, please post them on this thread.
      regards David
      Edited By David Clark 1 on 15/02/2012 11:30:03
      #22011
      David Clark 13
        @davidclark13
        #84854
        Ian P
          @ianp
          David
          Is the editor going to change, or has it already been changed?
          Having only a short memory I cannot remember what the old editor was like so I don’t know whether what I have just experienced is me or the new editor.
          A few minutes ago I replied to another post, I had written a few lines when (I think I may have pressed a wrong key by mistake) the editor window enlarged to fill the whole monitor.
          Most of the screen was the white editor window, with its pale blue bar and toolbar below the Internet explorer menu and toolbar. It went right to the bottom of the screen covering the windows taskbar (which I have locked/set to ‘stay on top).
          Whilst I could still get to other IE tabs I could not get the editor window back to normal size and had to abandon the reply by closing the whole tab.
          I looked in Windows help but whilst I can see how to minimise/maximise windows none of the commands work on the editor window.
          On the positive side, I have not been able to reproduce the problems again.
          Ian P
          #84858
          John Stevenson 1
            @johnstevenson1
            Posted by David Clark 1 on 15/02/2012 11:29:01:
            Hi There
            regards David
            Who’s going to be doing it now, you or another member of staff ?
            John S.
            #84861
            jason udall
              @jasonudall57142
              Sorry
              but the pm editor doesn’t work for me on phone. will have to drop out ’till I am behind desk…shame but there you go.
              #84864
              Peter G. Shaw
                @peterg-shaw75338
                Interesting point about this. A few years ago, I took on the job of creating a website for my choral society (because no-one else would do it even though at least one other person was capable of doing it). One of the things I learned in the process is that there was a minimum international standard for websites which most browsers including Internet Explorer (IE) did meet. However, IE (and others) did provide other facilities over and above the then standard. Unfortunately, some designers then produced websites which relied on these extra facilities and this meant that sometimes their websites would not work correctly with other browsers.
                It seems to me that this an instance where the designer has designed to a Microsoft IE design, not the international standard, and has now fallen foul of Microsoft “improvements”.
                I hope that Magicalia (or whatever the present name is) is taking the website designer to task over this because it does seem to me that he has not done his job correctly.
                Peter G. Shaw
                #84866
                Wolfie
                  @wolfie
                  I am a part time web designer and currently have 3 websites and 2 forums on line. When you create a website you should check it with the various browsers BEFORE you even go live. This is taught early on.
                  The minimum standard that Peter is on about is presumably the W3C one.
                  You want a hand moderating David give me a shout, least I can do for the help I’ve had on here. I note that some of the forum main titles are a bit out of date.
                  #84869
                  Diane Carney
                    @dianecarney30678
                    Posted by John Stevenson on 15/02/2012 21:15:07:
                    Hi There
                    regards David
                    John S.
                    That’s what I was wondering John! I am on annual leave this week. You turn your back for five minutes…………
                    Diane
                    #84873
                    Gone Away
                      @goneaway
                      Posted by Peter G. Shaw on 15/02/2012 21:33:08:
                      Same thing happened with Java some years ago. Microsoft started implementing its own version with numerous “improvements”. Pretty soon many websites wouldn’t work with standard (Sun) Java.
                      Sun sued MS for copyright violation and won (of course, but not before MS had dragged the whole thing out to try to make it too expensive for Sun to continue) and a subsequent OS update removed the MS version of Java. At that point, a whole bunch of websites stopped working,
                      Edited By Sid Herbage on 15/02/2012 22:44:08
                      #84879
                      John McNamara
                        @johnmcnamara74883
                        Hi All
                        Apart from compatibility with various web browsers to me the most glaring fault with the current system is the lack of compatibility with MS Word.
                        Not being able to cut and paste from Word is a serious issue. Like it or not the word processor of choice for the vast majority of the world.
                        I hope this post does not start discussion of (off topic) of Microsoft monopoly issues. We are talking about ease of use here for this website for the majority of users; not politics.
                        Cheers
                        Edited By John McNamara on 16/02/2012 00:26:10
                        #84881
                        _Paul_
                          @_paul_
                          If your making alterations for gods sake do something with your awful search “facility” just Searching for Keywords in a thread title went out with the Atari…
                          Paul
                          #84882
                          Ady1
                            @ady1
                            Just do a google site search
                            Edited By Ady1 on 16/02/2012 01:45:03
                            #84884
                            Terry Lane
                              @terrylane
                              Didja think you’d got the sack DC2? Dave did say text editor
                              #84887
                              Bazyle
                                @bazyle
                                Every forum is different due to the software they use and even with two using the same package the settings used make them different. It’s all part of the character and helps you realise which one you are on and so not post boring rubbish about computers on an engineering site.
                                erm hang on, I am on the geeksysoftwareforum.nut aren’t I?
                                #84892
                                Russell Eberhardt
                                  @russelleberhardt48058
                                  Posted by John McNamara on 16/02/2012 00:25:29:
                                  Cutting and pasting works just fine here from and to LibreOffice Writer so perhaps it is yet another case of Microsoft not complying with international standards.
                                  Russell.
                                  #84897
                                  The Merry Miller
                                    @themerrymiller
                                    Not
                                    Excellent idea John if only because it has a very good spell checker.
                                    Len. P.
                                    #84898
                                    John McNamara
                                      @johnmcnamara74883
                                      Hi Russell
                                      As I said before.
                                      “Not being able to cut and paste from Word is a serious issue. Like it or not the word processor of choice for the vast majority of the world.”
                                      Can you please substantiate that LibreOffice is in fact the word processor of choice for so many.
                                      Otherwise…..
                                      Please do not hijack the thread with diatribe.
                                      Cheers
                                      John Mcnamara
                                      Edited By John McNamara on 16/02/2012 10:20:42
                                      #84901
                                      David Clark 13
                                        @davidclark13
                                        Hi Diane
                                        You have not been sacked.
                                        Can you think of a better headline to make people read this thread?
                                        No, I thought not.
                                        regards David
                                        #84903
                                        Peter G. Shaw
                                          @peterg-shaw75338
                                          John McNamara,
                                          The only reason why Word is the word processor of choice is simply due to Microsoft's policies. Often, you will find a new machine may well have Works or a limited version of Office included. Furthermore, schools use Office – don't know why, but wouldn't be surprised to find that there has been some sort of financial deal done. In any event, Microsoft offer price reductions to any person who has a student, or student to be (pre-school child) in the house. Similarly, a lot of businesses use Office – again I would not be surprised to find a financial inducement based on quantity of licences bought.
                                          But, what about those individuals like myself who on a personal basis have no possibility of obtaining a price reduction. Are we to fork out large amounts of money for something of which we would probably only ever use a small subset of the facilities offered? Frankly, the answer is no – especially when there are alternatives available which are just as good.
                                          Frankly, it is high time that people like you accept and understand that there are good alternatives available. I have used Lotus Smartsuite in the past. I now use Open Office. I have even used a DOS based program which did everything that I needed, and more besides. Someone here has mentioned Libre – I have no experience, but I do know that people do use it.
                                          John, Microsoft is NOT the be all and end all of the computing world, and on a personal basis, the sooner that is realised the better.
                                          In respect of cut and paste, I have never had to do it yet – and I have produced some long posts. It simply is not necessary.
                                          Peter G. Shaw
                                          ps. Whilst on about it, why on earth do all those users of Word assume that everyone else uses Word and thus issue documents on the .doc format which again is NOT an international standard. It IS a Microsoft proprietory standard. What would Word users do if I sent them a document writen in the Open Office propretory standard, eg .odt? I rather imagine that they would not be able to open it.
                                          #84905
                                          dcosta
                                            @dcosta
                                            Hello all.
                                            Not having English as my mother tongue, sometimes I find is better to be shut up even if I feel I should intervene.
                                            This time I feel I must intervene and because of the above reason and also because Mr. Peter G. Shaw says eloquently the same I could say, I beg him permission to make mine his words.
                                            Dias Costa
                                            I made some tests pasting a few lines of text from Word 2003, Word 2007 and Open Office to this post as You'll see below.
                                            The only difference I found is only the text coming from Open Ofiice brought information on font.  The extra space between the lines was inserted by this new editor.
                                            The pasted lines are were extracted from Jethro Tull's Thick as a brick
                                            pasted from MS Word 2007
                                            See there, a son is born
                                            And we pronounce him fit to fight
                                            pasted from MS Word 2003
                                            There are blackheads on his shoulders
                                            And there he pees himself in the night
                                            We'll make a man of him
                                            Put him to trade
                                            Teach him to play Monopoly
                                            And how to sing in the rain
                                            Is this a too simple teste or am I missing something?
                                            Edited By dcosta on 16/02/2012 12:13:22
                                            #84906
                                            John McNamara
                                              @johnmcnamara74883
                                              Hi Peter
                                              I knew when I posted a suggestion that the site be made completely compatible with MS word that I would ignite the inevitable. As I said. " I hope this post does not start discussion of (off topic) Microsoft monopoly issues. We are talking about ease of use here for this website for the majority of users; not politics."
                                              I stand strongly supporting my suggestion that the site be made compatible with MS Word as a priority. This will fit the needs of the many…. It is your choice to use whatever software you choose. However do you really believe the Word users be punished…. A totally unreasonable concept.
                                              I hark back to the title of this thread
                                              New website editor
                                              It needs to be compatible with Word. Discussion of the rightness or wrongness of using Microsoft product is off topic.
                                              I intend to make no further comment on this subject unless it points directly to the thread heading.
                                              Cheers
                                              Edited By John McNamara on 16/02/2012 12:39:39
                                              #84907
                                              John McNamara
                                                @johnmcnamara74883
                                                Hi dcosta
                                                You are correct; it works some of the time. at other times it can make a post and the following posts unreadable by placing the advertisements to the right over the text, Word carries hidden punctuation and formatting data between lines of text, this often wreaks havoc with the MEW editor. There are other gremlins. Any software that only works some of the time needs to be fixed. Word works flawlessly with several other Engineering sites I post to.
                                                Cheers
                                                Katy Purvis
                                                  @katypurvis79544
                                                  Hi John
                                                  If I use the 'Paste from Word' button, I can paste from word. Please can you explain what doesn't work for you, and I will see how I can fix it.
                                                  Thanks
                                                  Katy
                                                  #84910
                                                  John McNamara
                                                    @johnmcnamara74883
                                                    Hi Katy Purvis
                                                    As I said above it works some of the time. I am sure it is the formatting characters that cause the problems.
                                                    From time to time I see the displaced adds on other MEW posters threads. there was one last week although I cannot remember where.
                                                    I stopped using word as an editor for this forum because of these problems. Quite frankly very inconvenient. As you are in the process of upgrading the Editor, surely there is a web page plug in editor that will not require a paste from word or any other editor button, there should simply be a paste text button or the shortcut ctrlV on the editor page to paste text as used by other Engineering forums.
                                                    Cheers
                                                    Edited By John McNamara on 16/02/2012 13:06:12
                                                    #84912
                                                    Katy Purvis
                                                      @katypurvis79544
                                                      Thank you John.
                                                      The displaced ads are usually caused by a long link in a post, if you report such posts when you see them, they can be edited and fixed.
                                                      I take note of your complaint about paste from word, and will investigate it further. However another upgrade to a different editor is unlikely to happen in the near future, as we have only switched to this one in the forum today.
                                                      Thanks for your comments
                                                      Katy
