Mystery brass container
Home Forums General Questions Mystery brass container
  • #320038
    Maurice Cox 1
      @mauricecox1
      I recently saved the brass container in the photos from going for scrap. It is 1 1/2 inches in diameter, and 4 1/4 inches to the thread. I am unable to get a readable picture of it, but it has " Moore and Wright, Sheffield, England. " engraved on its side. I assume that the larger cap is to allow ease of filling, and the smaller one to dispense the contents; but what? There are no seals or places for seals on the caps, so presumably not for a liquid. I would be very interested to find out what is was for.brass flask 2.jpgbrass flask 1.jpg
      Maurice Cox 1
        @mauricecox1
        #320041
        David George 1
          @davidgeorge1
          It,s part of a Moore and Wright spirit blowlamp there should be brass tube attached with a brass band.
          David
          #320043
          peak4
            @peak4
            I's suggest it's incomplete; there probably should be a clip round the outside holding a curved metal pipe with a fine nozzle on one end and a flexible rubber pipe on the other.
            Fill the cylinder with wadding and meths, take off the smaller cap, light the meths and blow down the tube.
            This gives a very fine precise blowlamp for small heating jobs.
            I'll root out mine and take a photo when I get chance,
            Bill
            #320046
            RJW
              @rjw
              +1 for Moore & Wright blowlamp, I've got a complete lamp in my workshop, yours is missing a brass tube which bends over the top of the small cap (removes to expose the wick) and is held by a large clip around the body, which should be filled with a cord wick, also should have a rubber tube and a mouthpiece to blow down, looks like a fake ivory job on mine,
              Unable to add photo's unfortunately, it's in another country to me at the mo'
              John.
              Edited By RJW on 04/10/2017 20:17:21
              #320053
              Maurice Cox 1
                @mauricecox1
                Thanks for that gents. Now you have told me what it is, I recognise it from my apprentice days with the G.P.O. (telephones). One of the construction engineers demonstrated one to us, but I can't think what work he did that would have needed one. That's probably why that was the last one I saw! Thanks again.
                Maurice
                #320054
                peak4
                  @peak4
                  Here you go,mine's missing the original cap, so sports one made from a brass nut with a plate soldered on to cover the hole.
                  The brass blow tube's a bit battered and now soldered on as well, but none of that is my handiwork.
                  Well worth buying if you ever spot one at a sensible price.
                  Bill
                  Edited By peak4 on 04/10/2017 20:50:25
                  #320055
                  Tim Stevens
                    @timstevens64731
                    For our friends overseas the term 'meths' is short for 'methylated spirit' – ethyl alcohol, burning alcohol, with added methyl alcohol and pyridine to make it smell and taste foul.
                    French DiY shops sell their version which is much nicer to use, not purple, and smells of brandy – which is what it is made from, I guess.
                    Cheers, Tim
                    #320058
                    martin perman 1
                      @martinperman1
                      Must find out where mine is.
                      Martin P
                      #320059
                      Clive Brown 1
                        @clivebrown1
                        I seem to remember a similar method of producing a fine, intense flame for chemical analysis in the school lab, but with glass hardware.
                        Experts were supposed to keep up the blowing indefinitely by beathing in through the nose while blowing through the mouth.
                        I couldn't!
                        #320064
                        Dod Mole
                          @georgeclarihew
                          Posted by Clive Brown 1 on 04/10/2017 21:35:41:
                          I couldn't!
                          Find a digideridoo player and ask him to show you how to breathe. smiley
                          #320070
                          Nicholas Farr
                            @nicholasfarr14254
                            Hi, these three scans maybe of interest.
                            Regards Nick.
                            #320078
                            not done it yet
                              @notdoneityet
                              l seem to remember a similar method of producing a fine, intense flame for chemical analysis in the school lab, but with glass hardware.
                              Was it blowing across a bunsen flame with either a metal, or hard glass, blow jet to heat up substances placed in a recess in a block of carbon?
                              Simple experiments for the effect of heat on a substance in a reducing atmosphere. Not allowed as soon as health and safety took over. I suppose sanitation of the blow jets, pupils sucking in hot gases, and idiots blowing hot powders around the lab, etc, etc put a stop to those interesting experiments.
                              Behaviour in schools has nosedived since the 1960s, to the point where this type of experiment can on
                              ly be undertaken under very close supervision or by alternative, less personally involved methods.
                              But I don't expect the secondary modern pupils of the time got the chance to investigate with chemicals like those in the grammar system, so the system of mixing all abilities together, in the comprehensive system has had a lot to answer for. There are always downsides to every system, I suppose. Comprehensive compromises is what I called it.
                              #320091
                              RJW
                                @rjw
                                Great scans Nick, you've just saved me a lot of googling for info, many thanks for posting them up, handy material to print off and keep with my burner cheeky
                                John.
                                #320112
                                  Posted by not done it yet on 05/10/2017 05:03:00:
                                  Yes with a Charcoal Block and also the Borax Bead Test.
                                  I know some of you chaps like to blame H&S for all the ills of the modern world but in this case they stopped teaching blowpipe technique because it has long been – more or less – obsolete. In the sixties some of the old fashioned analytical methods were still being taught (Chlorides detected with Silver Nitrate etc.) but much less than you would find in a Victorian Chemistry Textbook.
                                  Early on the process of identifying an unknown chemical involved many tests, each one designed to eliminate or prove the presence of an element, Anion or Cation. By very careful measurement of weights with a Chemical Balance it also was possible to extract further information about the unknown compound. As testing by these methods was skilled work as well as slow and tedious, much effort was put into finding better ways of doing it. Once they were available, there was very little point in teaching schoolchildren the older ways which is why blowpipes have all but disappeared and chemical balances sit in the corner.
                                  A word of advice: if you're inclined to automatically blame H&S for 'bad things', please don't. You are probably wrong. Check and double check the facts. For example, most UK towns used to have a foundry or two happily casting iron. Most of them have gone, not because of H&S, but because demand for cast-iron products has been falling for over a century. It is true that H&S and Environmental requirements were often the last straw, but most of those businesses were bankrupt already. It's also easier for employers to claim unreasonable H&S for their failures rather than poor management and bad investment decisions.
                                  H&S is a glorious opportunity to shift the blame. Engineers don't fall for such propaganda because it breaks the first rule of Engineering: 'thou shalt not solve the wrong problem'.
                                  smiley
                                  Tim Stevens
                                    @timstevens64731
                                    I agree with the gloriously mis-named S-O-D. But I have another reason for children to try old fashioned methods in science classes. One thing that the school process is intended to do is to help work out which pupils have particular aptitudes. In this case, an aptitude for science, including the practical application of theory, and the careful working out of answers from results. The carbon block, or borax bead, test, was easy to do as long as you did it right, it brought pupils face to face with risk and mess, and it did not require particularly complex or expensive or fragile equipment. So, for the purpose of weeding-out, it was a good exercise, even though it was no longer relevant in 'real' workplaces.
                                    Exactly the same things happened to engineering apprentices – filing exact cubes entirely by hand is not a regular task in 'real' engineering.
                                    Regards, Tim
                                    Edited By Tim Stevens on 05/10/2017 13:53:54
                                    #320178
                                      The Australians call it 'metho'
                                        Posted by Neil Wyatt on 05/10/2017 20:33:52:
                                        'The Purple Nectar' devil
                                        But seriously : http://www.wuchopperen.org.au/wp-content/uploads/2013/09/Doc0264_SMPMethoBrochure_v2.pdf
                                        Edited By Michael Gilligan on 05/10/2017 21:11:02
                                        #320307
                                        martin ranson 2
                                          @martinranson2
                                          Maurice … if you are ex-GPO, then do you remember 2 places called Otley and Stone ? that was a long time ago for me !
