Mystery bearing 1759X
Home › Forums › General Questions › Mystery bearing 1759X
  • #25137
    Rainbows
      @rainbows
      #288842
      Rainbows
        @rainbows
        Been disassembling a new lathe for just general everything refurbishment.
        The head stock bearings are both taper roller bearings marked
        "TIMKEN 1759X MADE IN ENGLAND N"
        Searching on the internet for the bearings doesn't find anything though.
        Would Timken make custom bearings where only something like 100 bearings get made?
        Bearing is 26.93*53.9*22.63 measured off my nasty calipers.
        Guessing the true value is 26.99*53.98*23.02?
        #288846
        HOWARDT
          @howardt
          Had a search it seems 1759x may be just the cone part of the bearing rather than the whole thing. Contact a dealer with the dimensions to get a correct identification.
          #288852
          Keith Long
            @keithlong89920
            Rainbows – check your measurements again and also measure the bearing in imperial units, it looks as though it could be a standard 0.875×2.125×0.9125 inch taper roller set – £27.21 each + vat from Simply Bearings.
            #288854
            Rainbows
              @rainbows
              Currently trying to work out how to pull out the cone. Will be able to get a better idea of size and maybe the real proper bearing name once I get it out.
              #291175
              Rainbows
                @rainbows
                In the somewhat unlikely event someone else finds this issue.
                The outer race is marked TIMKEN (R) 1730 MADE IN ENGLAND M and as stated before the inner race is TIMKEN 1759X MADE IN ENGLAND N.
                The bore is 1 1/8 while the documented size for 1730 is 1". Maybe timken made the inner race as a special for to the standard outer. Maybe someone just shoved two bearings together and hoped for the best.
                #291179
                John Haine
                  @johnhaine32865
                  Ketan, we need you!
                  #291191
                  Martin 100
                    @martin100
                    One of the headstock bearings on the boxford 3656 lathe was originally a composite of two timken part numbered somewhat similarly to this.
                    What make lathe is this 100 off special?
                    #291193
                    Rainbows
                      @rainbows
                      The 100 bearing figure was just pulled out of thin air. The lathe is a L S Blackman Maidenhead there was another thread in the forum about them. Brings the number of them known to 3 (assuming one of those lathes isnt the one I own now)
                      #291229
                      Martin 100
                        @martin100
                        Not that it will directly help you but this is a posting from here with referece to the oddball numbering and dimensions of the Boxford Headstock Bearings I referred to above, with the 'x' being presumably a designator for a metric bearing. Guess it's the kind of thing that only ever appeared in those huge bearing catalogues on real paper with greasy thumb prints that were probably discarded years ago.
                        #291234
                        martin perman 1
                          @martinperman1
                          If you can get access with an angle grinder grind a line down the cone then get a large cold chisel and place it on the ground line, a sharp tap should split the cone and it will slide off.
                          Martin P
                          Edited By martin perman on 30/03/2017 11:43:39
                          #291237
                          KWIL
                            @kwil
                            X is also used as an indication of "Precison Grade" bearings as used on spindles etc.
                            #291243
                            Martin 100
                              @martin100
                              Posted by KWIL on 30/03/2017 11:51:53:
                              Glad to be corrected, I had always thought it was indicated by one, two or three etched dots.
                              #291254
                              Rainbows
                                @rainbows
                                Posted by martin perman on 30/03/2017 11:43:02:
                                Martin P
                                Woops got my parts mixed up. Was the cup that was stuck. Similar to how you said though a carbide rotary burr got it out.
