Posted by Stub Mandrel on 26/03/2013 21:02:42:
That said, I still fancy changing to VFD, but I suspect it's a bit like putting alloy wheels and spoilers on a family car
Ah yes, plus a large chrome exhaust and lots of noise. And what do you get? A petrol to noise converter, but no extra performance!
To clarify a few (simplified) notes on three phase induction motors. First, a motor will be designed to produce its rated power at a given phase-to-phase voltage and frequency. The actual motor speed will depend upon the number of poles and 'slip', and is known as the base speed.
The current in the windings will depend upon the applied voltage, the impedance of the windings and the back emf, which is proportional to motor speed.
If we double the applied frequency, but keep the same phase-to-phase voltage the motor will run at twice its base speed. But the current in the windings will be reduced due to increased impedance and back emf. It is assumed that we cannot increase the voltage. Since the winding current has decreased the torque will have decreased, but the speed has increased. So, to a first approximation, the power (torque x speed) is constant.
If we now halve the applied frequency the motor will run at half its base speed. If we keep the same phase-to-phase voltage the winding current will increase, due to lower impedance and back emf. However, the losses in the winding resistance will increase as a square law. To counteract the increased losses the phase-to -phase voltage is reduced in order to reduce the current to that which would flow at base speed with rated voltage. The consequence of this is that below base speed the torque stays constant but the power decreases proportionally. So below base speed the motor is essentially constant torque.
Most 'simple' VFDs run a V/F algorithm, ie, as the frequency decreases the applied voltage is decreased to keep the winding currents roughly constant. Sometimes the algorithm is 'tweaked' at low frequencies where the winding resistance causes the basic V/F curve to underdrive the current in the windings. It is also possible to programme the VFD to run the motor below base speed with a percentage 'overload' on the current; fine for short term transients but may lead the motor to overheating if over done.
In summary, above base speed – constant power, below base speed – constant torque.
Russell: I assume that the VFDs that can generate 415V phase-to-phase from a 240V input probably incorporate a power factor corrector, also acting as a boost converter, in the first stage rather than voltage doubling or a charge pump.
