Well-spotted, Niko
Mine [currently dismantled] is quite badly worn ‘bell-mouthed’ as a result of this.
Although the motor shaft has a keyway, the pulley was retained by just a single grubscrew [which must have come slightly loose]
and the pulley, with its oversize bore was rocking on that.
Both motor-shaft and pulley now need attention
… but I will probably fit a 3-phase motor and then ‘bore & bush‘ to suit
