Myford leadscrew bracket.
Home › Forums › General Questions › Myford leadscrew bracket.
  • #284973
    Adrian 2
      @adrian2
      Morning all,
      Does anyone have experience of removing the right hand leadscrew bracket on the Myford lathe ? In addition to the two cap head screws there are two dowels tapped to aid extraction . Not sure which thread as they are damaged. With the screws removed the bracket is still firmly held in place by the dowels.
      I'm thinking a simple extractor to draw the dowels and bracket off as a unit. Any advice appreciated thank you.
      Adrian.
      #25088
      Adrian 2
        @adrian2
        #284976
        Lambton
          @lambton
          Adrian,
          Looking at the parts list in the Myford handbook the dowels are standard plain ones. They are, like all good dowels, a very close fit in their holes and are therefore difficult to remove. Try gently prising the bracket off using the "two screwdrivers" technique. Go gently a little at a time and you should have no trouble.
          Eric
          #284982
          John Haine
            @johnhaine32865
            The dowels are tapped 4 BA. You need a few inches of 4 BA studding, a BMW weight say 1" diameter and a couple of inches long drilled to clear, and a 4 BA nut. Nuy on one end of stub, thread through weight, screw other end into dowel, then slide weight smartly against nut a few times to extract dowel.
            #284992
            Adrian 2
              @adrian2
              Thank you for your replies. The slide hammer idea sounds good . I will do it that way.
              Adrian.
              #285001
              Lambton
                @lambton
                Just been to look at my lathe and I confirm that the dowels are tapped. Very thoughtful of Nottingham Myford.
                #285051
                John Purdy
                  @johnpurdy78347
                  I have removed the bracket a number of times by screwing in a 1" 4BA screw and giving the head a good tug with the fingers. Mine are a snug but sliding fit in both the bed and the bracket.
                  Adrian 2
                    @adrian2
                    That's encouraging John, it may not be as difficult as I at first thought.
                    Adrian.
