Myford chucks
Myford chucks
Home › Forums › Beginners questions › Myford chucks
  • #70147
    Mark Millward 1
      @markmillward1
      How far should chucks go onto the spindle thread of an ML7 ? Put another way, how many turns is a minimum ? None of mine go fully on and all seems very clean.
      Mark Millward
      #5541
      Mark Millward 1
        @markmillward1
        #70148
        Clive Hartland
          @clivehartland94829
          Mark, they should go right up to the face of the mandrel.
          If they do not then re-clean the male and female threads and try again.
          If you still have trouble then using a cotton wool bud apply a smear of blue on the male thread and plain part and see where it is catching.
          I have noticed on my 3 jaw chuck some slight scrape marks inside the plain part of the chuck body as if someone has relieved the plain part!
          I dont use any lubricant on my chuck threads at all. The only part I clean and lube is the scroll and jaw teeth. For this I use a stiff graphite grease.
          Under no circumstance try and force the chuck onto the mandrel, it should go very easy if clean.
          #70149
          Tony Pratt 1
            @tonypratt1
            The chuck should screw on until the chuck register face meets the spindle register face, the threads shouldn’t bind at all.
            Tony
            #70150
            Chris Trice
              @christrice43267
              Are the chuck bodies threaded or are they fitted to a backplate? If a chuck backplate has been machined too thin, the spindle nose can protrude through it and contact the rear face of the chuck body stopping it screwing fully home.
              #70162
              David Clark 13
                @davidclark13
                Hi Mark
                Take the chuck of the backplate.
                Does the backplate go right up to the shoulder?
                It should do.
                regards David
                #70230
                Mark Millward 1
                  @markmillward1
                  Thanks for your replies. I have spent ages cleaning the threads and things are getting easier. I believe a bit of aluminium swarf got in the thread and caused the binding. I should like to run a tap and die over the threads but they seem a bit expensive so will persevere with the wire brush and magnifying glass. Thanks again.
                  Mark
                  #70238
                  KWIL
                    @kwil
                    Mark,
                    You can make a thread cleaner for the backplate from a piece of piano wire, a long half loop with the ends turned outwards, with enough spring to push into the bottom of the threads, but not that much that it scratches the metal. I am not as keen as Clive on no lubricant, a trace of sewing machine oil should suffice. I have the taps but I do not suppose you are anywhere near.
                    #70252
                    Chris B
                      @chrisb73862
                      I used a 4″ nail bent into an L shape, the point gets into the root of the thread and will displace any swarf when you run it round the thread.
                      #70263
                      The Merry Miller
                        @themerrymiller
                        I use a small wooden backed brass wire brush that effectively screws itself into the thread and out the other side.
