The actual headstock can be locked at a required position the use of a dial comparator makes the alignment of the tail stock straightforward .
the lathe was purchased for its ability to used as a bor mil lathe for basic machining ,I have been using the ability of the head stock vertical movement to cut the new gears required to replace the missing change gears .
I shall fabricate the gear banjo's, machine a new chuck back plate with an 1-7/8" 8TPI thread, remove stuck chuck "machine off as last resort" which will release the full potential of the little Murad.
I have retired from a working life in engineering ,time served indentured apprentice at John Thompsons Boiler makers worked their most my life as:- draughtsman ,boiler maker, fabricator ,maintenance fitter, welder. Had to change jobs as the work gradually declined. The lathe in the Mars shop was so big the turner had a table and chair on the tool post it's a housing estate now.
Regards Eric
