Quite right Michael, the bearing is in the quill and heads, any minute play even if Timken would induce vertical and lateral movement even though quill locked up. Minimal though.
Far greater movement is often experienced with poor build machines, you can visually see a Wabeco mill bounce and deflect on the upright column yet alone the head.
Right Jim pretty much same machine as mine, the geared head is very heavy hanging off a dovetail. Lock it up, put a cut on and you will see vibration/deflection originating from this joint, i grolly mine up and still see it. No visual or felt vibration or movement on upright dovetal column.
Another area due to the build is the quill in the casting fit, it will wear quick.
Precession then would cut oversize right angles to the torque.
Another for Michael and Jim is when tension is on the quill winding upwards, zero DRO and take a cut.
Now try winding down to zero with tension on, it will be something else.
If no play should come out the same. I dont get this off the spare RF25.
New decent quality bearings if anything too tight.
Found coolant pump today Jim, had it 7 years.
The CNC was probably better built and running a lot faster, the downside of the ZX40/45 series.
I am after the transfer box bolted to upright column between the elevation motor if you convert it.
