Although most of my learning was done on my father's 803cc Morris Minor (The engine was a Longbridge design, now known as the BMC A Series ) my test was actually taken on a 1934 Austin 10.
It had been stored all through the war, with the handbrake hard on, so that the brake drums were oval. This meant that when the foot brake was applied, the pedal rose and fell under your foot!
No matter how carefully the brake compensators were adjusted, it would not pull up in a straight line when braked hard. During the test, some steering lock had to be applied to have a reasonably straight line pull up , for the Emergency stop!
The clutch pedal had the short travel that was common to Austins of that vintage. The pedal was attached to lever that was directly arttached to the shaft carrying the clutch throw out fork!
Adjustment meant slackening a pinchbolt, and moving the lever relative to the shaft before retightening the pinchbolt.
The clutch was unusual, since the friction facings were attached to the Flywheel and Pressure Plate, with the Centre Plate being plain steel.
This arrangement survived into the modernised pre-war version of the car, known as the Austin Cambridge, which my brother had at one time.
It was none too tolerant of oil contamination, which caused it to slip!
The valve springs were retained by a pin passing through the valve stem. The lower spring plate was counterbored, so that the spring pressed the plate over the pin to prevent it falling out.,
After a de coke, valve grind and tune up, with a following wind, it was sometimes possible to see 60 mph on the speedo!
