ml6 nose thread
ml6 nose thread
Home › Forums › General Questions › ml6 nose thread
  • #244553
    mick70
      @mick70
      Does anyone know the thread size on nose of an early ml6?
      Trying to work out adaptor for it to use a small chuck using a back plate.
      At work for next few days so can't check mine.
      Ta
      #24609
      mick70
        @mick70
        #244606
        Brian Wood
          @brianwood45127
          I don't know, but Myford adopted a nose thread of 1.125 inch by 12 TPI Whit for the early ML2 to ML4 lathes and carried that through to the ML7 lathes and the variants; I imagine it would be logical for them to adopt the same method on an ML6. a lathe incidentally I have never seen.
          #244607
            Posted by Brian Wood on 29/06/2016 09:10:36:
            ML6 appears to be an interesting machine !!
            4" Taper Roller Bearings … In a Myford
            Ady1
              @ady1
              It looks like it has a solid bed? Certainly a solid lump of a machine that one
              #244663
              mick70
                @mick70
                from rough memory it is closer to 2", i briefly looked at doing project last year.
                also want to make adaptor so i can use collet's from it on my main lathe as well.
                if you look in my albums there are pics of it in there.
