Posted by Michael Gilligan on 15/01/2017 16:35:48:
You could use a draughtsman's 30° 60° 90° set-square … probably quicker.
Only if you happen to have one
As Michael says a set-square is quick and usually accurate enough, easy if you have a dovetail column mill to hold one side agaist that and the othe against the fixed vice jaw or a flat bar held in the vice
I see there is also an incline function, this can be used in a similar way as the linear pattern, just enter a large value for the step say 2" or 50mm and angle of 30deg.
Another option if you have a rotary table is to mount the vice onto that and clock it in true then rotate table 30deg.
