Milling M3 collet chuck in the lathe
Home › Forums › Beginners questions › Milling M3 collet chuck in the lathe
  • #313466
    Alfie Peacock
      @alfiepeacock58331
      This is a basic question about my M3 collet milling chuck, can it be used in the lathe buy just tapping it into the tapper with a mallet. As it uses the draw bar in the mill will it be ok in the lathe without using the draw bar.
      #8841
      Alfie Peacock
        @alfiepeacock58331
        #313467
        Emgee
          @emgee
          Hi Alfie
          I would suggest you make and use a draw bar, tapping the collet chuck to secure in the taper or to remove from the taper is not good for the headstock bearings. I made mine using threaded rod and a top-hat threaded heavy washer at the spindle end.
          If you have a gap at the chuck to spindle point you can make and use a wedge or a pair of wedges to remove the chuck.
          Emgee
          #313630
            As Emgee suggests, a milling cutter causes too much vibration. You can use studding and a suitable washer and nut at the end of the spindle, it doesn't need to be super tight, just secure.
            #313642
            Alfie Peacock
              @alfiepeacock58331
              I've got some studding so will make that, but Im not sure what Neil means by a milling cutter causes too much vibration.
              Alfie
              #313653
              Roderick Jenkins
                @roderickjenkins93242
                Drill chucks are held in place by the pressure of drilling pushing the taper home axially. Milling cutters produce alternating side loads with very little axial pressure and these will tend to loosen the taper.
                HTH,
                Rod
                #313654
                Emgee
                  @emgee
                  Alfie, no doubt Neil means if you don't use a draw bar to secure the collet chuck the milling forces may cause the taper fit to let go. Milling puts side forces on the chuck unlike drilling operations.
                  Emgee
                  #313677
                  Alfie Peacock
                    @alfiepeacock58331
                    Thanks for the advice,its obvious now when thinking about it .
