milling lathe cutters
Home Forums Beginners questions milling lathe cutters
  • #287593
    phil1962
      @phil1962
      Hi fellas can you cut 4mm of the bottom of 12 x 12 mm cutters I need to make the 8mm the cutters are the insert type if so can anyone here do it for me ? cheers phil.
      #8602
      phil1962
        @phil1962
        #287596
          If they are ordinary steel holders you should be able to cut them with HSS tools.
          Why not mount them cross wise in a 4-jaw chuck and face off the extra 4mm?
            A lot will depend on the hardness of the tool holder, I have done it in the past and blunted the three tips on the first milling cutter I tried but did manage to remove the metal with another insert tool.
            If your 12×12 holder was not that expensive then it may just be cheaper to buy a smaller size than risk the cost of blunting tools finding out how hard it is.
            #287605
            phil1962
              @phil1962
              Posted by Neil Wyatt on 07/03/2017 18:09:57:
              I don't have the skill as just starting I got the cutters thinking they would fit I tried to return them for smaller ones but they don't have any they will only give me a credit note to get something else but have nothing I want so stuck with them
              #287606
              phil1962
                @phil1962
                Posted by JasonB on 07/03/2017 18:17:12:
                hi this is the set http://www.ebay.co.uk/itm/7-Set-12mm-Shank-Lathe-Turning-Tool-Holder-Boring-Bar-CCMT-MGMN-Carbide-Insert/332094505249?_trksid=p2060778.c100290.m3507&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D40964%26meid%3D29dcd7b1529b4d80b7f305212f998c79%26pid%3D100290%26rk%3D3%26rkt%3D4%26sd%3D371875029172
                #287607
                phil1962
                  @phil1962
                  the boring bars are both ok as they sit 2mm lower than centre so can be shimmed up
                  #287608
                  Robbo
                    @robbo
                    "A lot will depend on the hardness of the tool holder" says Jason, and quite rightly.
                    Test yours with a hacksaw or file, some are quite soft, or only surface hardened. I have taken material off using an angle grinder followed by a grindstone to finish – marked out properly to start with of course.
                    If you can't do it, then by the time you've posted it/them to and fro to someone who can you may as well buy a new one. And if the holder is very expensive then it is also probably very hard.
                    #287611
                      Posted by Robbo on 07/03/2017 18:51:03:
                      So you may be lucky as those chinese via Gurnsey holders for less that £4 each may be rather soft. blush
                      #287612
                      phil1962
                        @phil1962
                        there's five all together I think its only the tips you put in that are hard but will test with a file
                        #287613
                        Steve Addy
                          @steveaddy35670
                          I have just had a look at the original link – he doesn't have smaller ones, also checked Banggood, they don't either! Chronos have a nice set but it isn't that price! Incidentally i have been using CCGT inserts which are sharp and have lots of rake. Meant for aluminium, they work well in the lighter sort of machines we tend to have.
                          Steve
                          #287615
                          phil1962
                            @phil1962
                            good price but wrong size lol sure it would take someone that knows what there doing two mins to do but I don't have the skill as just starting
                            Edited By phil1962 on 07/03/2017 19:23:32
                            #287617
                            MW
                              @mw27036
                              A crude way to test the hardness of the holder would be to see if you can mark it with a dot punch or take a file to it.
                              Michael W
                              #287648
                              Chris Evans 6
                                @chrisevans6
                                Where in the country are you ? If they are not overly hard someone close by should be able to help. I am in the Midlands close to Lichfield.
                                #287690
                                Ian S C
                                  @iansc
                                  023 (640x480).jpgIf they are too hard, and you have one, get going with your angle grinder, I converted some old HSS flat bits into lathe tools with the aid of my angle grinder.
                                  Ian S C
                                  #287698
                                  phil1962
                                    @phil1962
                                    Posted by Chris Evans 6 on 07/03/2017 21:45:35:
                                    Where in the country are you ? If they are not overly hard someone close by should be able to help. I am in the Midlands close to Lichfield. I live in Rugeley so not to far from u I don't think the holders are made from hard metal but the inserts that go into the ends are they are same as these the two boring bars are ok as they sit 2mm under centre so can be shimmed up but the other 5 need 4mm skimming of bottom to 8mm
                                    Edited By phil1962 on 08/03/2017 09:17:06
                                    Edited By phil1962 on 08/03/2017 09:19:12
                                    #287700
                                    Chris Evans 6
                                      @chrisevans6
                                      Phil, looks like we are close as I am in Kings Bromley. PM me your contact details and I will do them for you. My machine is set up with a rotary table for the next day or so then I can pop a vice on for you. Regards Chris.
                                      #287702
                                      Vic
                                        @vic
                                        I had to cut a few mm off the bottom of a 20mm Sandvik tool holder for a mate. It was tough going but a carbide mill did the trick.
                                        #287705
                                        phil1962
                                          @phil1962
                                          Posted by Chris Evans 6 on 08/03/2017 09:26:11:
                                          That's fantastic Chris thank you very much PM sent
                                          #287707
                                          phil1962
                                            @phil1962
                                            I tested one with a file and bits were coming off so metal not to hard
                                            #287997
                                            phil1962
                                              @phil1962
                                              Would like to say a big thank you to Chris Evans for sorting my lathe tools I can now use my lathe thanks to Chris that's some milling machine and lathe you have there your a Gent many thanks ATB Phil.yes
                                              #288048
                                              Chris Evans 6
                                                @chrisevans6
                                                Glad to have got you sorted Phil. Yes they where tough but no match for the carbide cutter, you would not have cut those with HSS tooling. Chris.
