The world of model and hobby engineering
Forums
Help
Register
Log in
Home › Forums › Beginners questions › Milling depth of cut
Is there a good rule on the max depth of cut that can be used for slot milling?
Is that the same for end milling?
Is 1/3 of the cutter diameter correct?
Typically 1/2 x diameter for slot drills 1/4 D for end mills but a lot depends on the rigidity of your mill. For light hobby mills perhaps half that.
Russell.
Depending on material and set-up I start at cutter diameter as max depth of cut for a slot using a 2 flute cutter.
Emgee
And what is the reason for this limitation is it the strength of the cutter or the removal of swarf?
If it is swarf can you cut through a material to a greater depth than you can cut a slot in it?
Started by: James A in: Workshop Tools and Tooling
Started by: Nigel Graham 2 in: Manual machine tools
ega
Started by: old mart in: Hints And Tips for model engineers
old mart
Started by: petro1head in: General Questions
petro1head
Started by: Michael Gilligan in: The Tea Room
Vic
Started by: Meridienne Exhibitions 1 in: Exhibitions, Shows and Club Events
Started by: vic newey in: Workshop Techniques
vic newey
Started by: Durhambuilder in: Electronics in the Workshop
Started by: Colin Heseltine in: The Tea Room
Colin Heseltine
Started by: JasonB in: The Tea Room
bernard towers
Started by: Terry Nicholas in: General Questions
Started by: BOB BLACKSHAW 1 in: Workshop Techniques
BOB BLACKSHAW 1
Started by: Another JohnS in: General Questions
renardiere7
Started by: Werner Schleidt in: Traction engines
Werner Schleidt
Started by: hclmetal2026 in: CNC machines, Home builds, Conversions, ELS, automation, software, etc tools
hclmetal2026
Started by: Bazyle in: Exhibitions, Shows and Club Events
paul1956
Started by: David George 1 in: Workshop Tools and Tooling
David George 1
Started by: duncan webster 1 in: Locomotives
duncan webster 1
Started by: Luker in: Locomotives
Started by: Andy Brocklehurst in: General Questions
Andy Brocklehurst
Started by: gregmallitt in: Introduce Yourself – New members start here!
Zan
Started by: Franco Convertini in: General Questions
Started by: Mike Hurley in: The Tea Room
Nicholas Farr
southernchap
