Mill spindle trouble?
Home › Forums › Beginners questions › Mill spindle trouble?
Viewing 25 posts - 1 through 25 (of 45 total)
  • #81539
    Wolfie
      @wolfie
      OK as you know I have finally acquired a milling machine, an Amadeal XJ300-12.
      It arrived yesterday and I’ve been setting it up and cleaning that awful grease off it and finally started to use it this aft..
      I have an ER25 collet set so was using that. The first thing I had to do was drill a number of holes and I started to notice that the holes were slightly different diameter top and bottom. Tapered slightly in other words. Wider at top than bottom.
      Looking at the top of the spindle where the drawbar pokes out, there is a clear wiggle going on. Not much but I can see it. Same at the bottom but I couldn’t see it until I started using an endmill which is much bigger than the drill I was using.
      The implication here is that the mill spindle is slightly out. I’d like to strip it and put it right but I’m not very familiar with these machines. I do have the manual with it but the translation leaves something to be desired, (apparently it has foxes but I haven’t found them yet!).
      I do however have an exploded view of the spindle but its not very clear. What should I do?
      #5844
      Wolfie
        @wolfie
        #81540
        V8Eng
          @v8eng
          Hi.
          Personally speaking (if it’s new & under warranty), I would stop using it and contact the suppliers about the problem on Monday.
          Edited By V8Eng on 07/01/2012 19:42:31
          #81541
            As said if its new have a word with Amadeal first.
            I had similar on my X3 when I got it, the adjusting nuts on the spindle bearing were loose and just needed nipping up to get rid of teh 0.030″ play in teh spindle.
            J
            #81542
            Ketan Swali
              @ketanswali79440
              I don’t know the machine, but it looks similar to an X2 head. If so, I go along with what JasonB has said. It may be that the locking nuts may have become loose.
              If it is similar to an X2, look on ARC’s website at the C3 mini lathe preparation guide and/or bearing change guide. The X2 head is more or less a mini lathe head stock turned vertical.
              Ketan at ARC.
              Edited By Ketan Swali on 07/01/2012 20:07:57
              #81546
              Wolfie
                @wolfie
                I suspect you are right. Thanks for that Ketan it looks similar-ish.
                I’ve sent Amadeal an email just in case but I’ll go have other look at it tomorrow now I’ve seen that C3 stuff.
                Am I likely to need bearing presses?? And does it also follow that replacing chinese bearings with taper bearings will improve matters??
                Still ain’t found the foxes
                #81555
                Wolfie
                  @wolfie
                  You are absolutely right Terry and I will not be fobbed off.
                  #81567
                    Wait to hear from Amadeal first, I’m sure that if you mention that you have asked on a Forum they will want to ensure the matter is resolved quickly
                    You won’t need to actually remove the bearings so no press required, it just that the two bearings may not quite be set close enough together and just tightening the nut will close them up enough.
                    The main thing to establish will be is it due to the bearings or is there a bend in the spindle, you may be able to feel movement by holding the chuck and pulling back & forth.
                    J
                    #81574
                    Ketan Swali
                      @ketanswali79440
                      Posted by Wolfie on 07/01/2012 22:11:20:
                      Hi Wolfie,
                      To establish how close it is to an old/original X2, go to this link and open up the exploded diagram as suggested near the top of the page.
                      Broadly speaking, if the head is similar, what JasonB suggests is correct, and hopefully, just tightening the nuts which might have become loose in transit, or incorrectly assembled, could solve your problem. Before tightening them, take them out and have a look at them, to avoid cross threading, if you feel that this might be a concern.
                      A bend in the spindle is rare. Too tight spindle diameter tolerance could effect how easily the bearings were/or not mounted onto the spindle, and how they are sitting on the shaft/in the casting. Assembly could be an issue. If this is an issue, then a puller of some description will be required, and you may or may not wish to rectify this part of the assembly yourself or send back to Amadeal to solve for you, if you still want the machine and not want to send it all back.
                      Replacing bearings is a secondary issue to be considered only if you are not happy with the results. I don’t know what bearings are inside your machine. Have a look on the parts list and state what bearing are there – it does not matter if it is a Chinese bearing number or an SKF number. We can then figure it out.
                      If they are ball raced bearings – doesn’t matter if they are Chinese or European in this particular instance. You can put a better pre-load on taper roller bearings or angular contact ball bearings then you can on ball bearings. So, in this respect, the results will be improved if you use these bearings over ball raced bearings.
                      If you have 6206-2RS bearings inside, you could replace them with 30206 taper roller bearings. We have not tried this, but we are aware that others have, with improved results. the concern here is that 30206s are wider than 6206-2RS, so some modification to a spacer may be required, but as we have not tried this on an X2, I cannot say for sure.
                      We will be offering 7206B-2RS sometime this month. Dimensionally, they are same as 6206-2RS. They will allow faster running than 30206 taper rollers, they are sealed. 30206s are not.
                      Ketan at ARC.
                      #81577
                      Wolfie
                        @wolfie
                        Looking at that diagram, its identical in the spindle area. I’m going from memory, the machine lives in my workshop which is elsewhere in town. There are differences elsewhere but I’m pretty sure the spindle and motor unit is the same.
                        Which is the bearing nut, if its no119 (spindle nut) then I’ve already removed it, cleaned it and tightened it back down. Thats the one I can see has a wiggle on when its turning.
                        #81578
                        Ketan Swali
                          @ketanswali79440
                          Yes 119. Is it a wiggle because of the way the nut looks – i.e.machined on the o.d., or does the nut look properly machined?
                          If the nut looks properly machined, then it does seem that there could be an overall assembly issue. So, from here on, it is up to you how you wish to deal with it.
                          If it was me, I would speak to Amadeal and ask them if they are happy for me to take the spindle out and have a look, for the purpose of correcting or replacing.
                          Ketan at ARC.
                          #81579
                            The fact part 119 is retained with a grub screw from the side could be wahts making it look eccentric or its just bored off centre, its the spindle you want to see the wobble on or not.
                            J
                            PS My X3 mentioned above did not come from Ketan@ARC
                            #81585
                            Ketan Swali
                              @ketanswali79440
                              Hi JasonB,
                              …I don’t think it matters that your X3 came from ARC. From time to time, all sellers have problems with machines supplied by them…even ARC…
                              I was just interested in this particular post, and wanting to figure if and how it was possible to solve this problem.
                              Forums are a good place to try and find constructive help.
                              Thanks, Ketan at ARC.
                              #81586
                              MICHAEL WILLIAMS
                                @michaelwilliams41215
                                Hi Wolfie ,
                                Start your observation in a different place – Put a clean reasonably accurate plain bar in your collet and see what that does . In particular whether it runs true at both ends and whether (with power off ) you can waggle it about . Doing these tests with a dial gauge would be an advantage but you can usually see enough by eye to detect any major problem .
                                Seeing whether a nut or sometimes even a collet chuck body are running true is no guide as to what the actual spindle is doing .
                                Don’t forget to check for up and down slop as well .
                                On your original point – drilled holes that are not done by rather pedantic methods are often a bit wider at the point of entry than they are over most of the remaining depth . Drills have very poor centering action and can often bounce around a bit before settling down .
                                MW
                                #81587
                                NJH
                                  @njh
                                  Ketan
                                  It’s greatly to your credit that you are prepared to jump into this bear pit and offer informed, constructive, advice on another supplier’s problem. I’m not in the market for any more machinery but, if I was, I would certainly consider yours.
                                  Norman
                                  #81589
                                  Wolfie
                                    @wolfie
                                    Thanks all for suggestions, I will check it with a DTI this aft. Its terminology again, what are:
                                    run out
                                    up and down slop?
                                    Don’t think that grub screw was done up, would that make a difference?
                                    I agree with Nigel, Ketan  your help is very welcome to a beginner.
                                    Edited By Wolfie on 08/01/2012 11:39:13
                                    #81594
                                      “Don’t think that grub screw was done up, would that make a difference? “
                                      Yes it will could have allowed the nut to come loose and therefore the bearings will be sloppy.
                                      J
                                      #81601
                                      Wolfie
                                        @wolfie
                                        OK chaps looks like its egg on face time.
                                        I went back up to my workshop (parents garage) today and had a much closer look. I believe as someone said that I have been fooled by the way both the nut and an endmill look when turning at speed assisted by the fact that the top of the drawbar isn’t quite concentric with the spindle.
                                        As they have projections/indentations it gives the effect of movement side-to-side. So I put a piece of more or less parallel bar in the collet, tried to move it and then applied the DTI.
                                        Results as follows: Couldn’t find any play in spindle by moving bar.
                                        DTI on morse taper and collet holder, very little deviation at all
                                        I then applied DTI to bar, top, middle and bottom. Top and middle, 0.1mm deviation and maybe 0.3 at the bottom.
                                        I can also report that having milled the tops of some clamps I’m making, they are square both ways on so I reckon its OK.
                                        Looks like I got that one wrong, fooled by a bloody nut doh! Apologies all round but thanks for the help anyway.
                                        HOWEVER! I tried to slot mill for the first time ever and on plunging the slot mill I encountered an awful lot of vibration. This was countered to a degree by doing up the gibs, but still was a bit rough.
                                        I was cutting a slot in 8mm steel, and when I went all the way through and then cut the slot, the slot is a bit ragged but when I went down a bit and then across and then down again and across it was much better. Is this normal?
                                        Clamp on right, slot cut in one hit, note the wandering, clamp on left, slot cut in 4 passes. Much better but note top end where it is slightly larger due to vibration on plunging.
                                        #81602
                                          On an X2 size machine I would think an 8mm cutter would take about 1mm depth at a time in steel.
                                          J
                                          #81605
                                          Wolfie
                                            @wolfie
                                            So doing the 8 mm slot in one hit was a no-no then?
                                            I did 3 like that
                                            #81610
                                            Ady1
                                              @ady1
                                              You’ll get a nice purring whirry noise if everything is perfect as a milling cut progresses.
                                              If there are any issues then you’ll get various noises and vibration.
                                              Like with a lathe, but with a lathe a good cut produces a nice hiss.
                                              I also drill some strategic holes with a drill bit first when possible.
                                              Drills cost buttons and can be resharpened in seconds and some strategic holes can save a fair amount of work for a slot drill
                                              Edited By Ady1 on 08/01/2012 21:08:00
                                              #81612
                                              Sub Mandrel
                                                @submandrel
                                                Wolfie,
                                                It all depends. On my X2 I have happily been taking 11.5mm wide cuts in cast iron with no trouble- its lovely ‘soft’ cast iron. Then today I hit real trouble on a much smaller cut -blunted a freshly sharpened cutter – it turned out there was some moulding sand stuck to the iron under old paint and the shallower cut didn’t get underneath it
                                                I also was milling 3/8″ by 1/16″ slots with no trouble.
                                                I would say go by the amount of vibration – the machine will tell you when its unhappy.
                                                Wolfie
                                                  @wolfie
                                                  I wondered about drilling a hole for the slot mill to start in, is this good practice?
                                                  #81617
                                                  David Haynes
                                                    @davidhaynes53962
                                                    I would like to add what Norman has said about Ketan ‘jumping into this bear pit!’ Whilst a cynic may say that a supplier has ulterior motives in being on the forum, and although there is mention of Arc products in passing, having spoken to Ketan at length after I made an enquiry about the X2 mill (he rang me back), I found him affable and knowledgeable about the product. Whilst, again, it could be argued that this is all about sales pitch, I genuinely feel that he is interested in his subject, whether there is the sound of a cash register in prospect or not. Incidentally, he was explaining how they had improved the X2 with motor and drive changes that made it different to others.
                                                    Wolfie, I am sure with patience you will get things ticking over fine!
                                                    Nicholas Farr
                                                      @nicholasfarr14254
                                                      Hi Wolfie, I drill holes at the beginning and at the end of a slot before using a slot drill. Below is a picture of a eccentric plate that I made as part of for an attachment for my milling machine, it shows a series of holes I drilled either 6 or 6.5 mm before slotting with a 7 mm slot drill. The second picture shows the finished plate with a good view of one of the slots.
                                                      Regards Nick.
                                                      P.S. The thickness of the plate where the slot is, is around 15 mm and the diameter of the plate is around 130 mm.
                                                      Edited By Nicholas Farr on 08/01/2012 23:29:12
