Anybody have an opinion?
Well – from experience with lubrication of gearboxes in “full size” machines I would suggest hydraulic oil would be a good place to start. More machines that I have come into contact with have used hydraulic oil to lubricate spindle gearboxes than any other type of oil. I seem to recall the odd one that used slideway oil & one (a Brown & Sharpe VMC) that used ATF, but non spring to mind that specified a gear oil.
Viscosities vary – and some of the bigger machines use the lighter oils. Most large vertical borers (Webster & Bennett, Schiess, Froriep, Morando, OM) specify 32 viscosity oil. The Gildermeister lathes at my current workplace specify 46 viscosity hydraulic oil for the spindle boxes, as does a Kira VMC. A Dixi CNC borer I once worked on used 10 weight oil – like water ! I have seen the gears on vertical borers (I used to work for a CNC machine tool rebuild company) that had done over 20 years service (37Kw motors usually) that still showed the original grinding marks on the teeth, so ISO VG32 hydraulic oil seems to provide sufficient lubrication.
I don’t have any experience of piston compressor oils, but suspect that they would be optimised for constant high temperature operation – maybe over extended periods. All piston compressors I have worked near have run hot. I suspect they would have similar characteristics to monograde engine oils.
My first preference would be to use a 46 viscosity hydraulic oil, but if no industrial suppliers nearby, then use ATF. I use ATF in the head of my Taiwanese Emco FB2 clone. ATF & hydraulic oils have added extreme pressure & anti-foaming additives and good viscosity stability with temperature change (think of the lubrication requirements of gear or piston pumps). Lighter weight oils will give the motor an easier time at start-up – higher viscosity may give better noise damping (maybe the reasoning behind a recommendation for 68 viscosity).
Other opions will, no doubt, be along in a momemnt !
Nigel B
