marlco thread parallels
Home › Forums › General Questions › marlco thread parallels
  • #65609
    Michael Devlin
      @michaeldevlin84947
      I have a set of Whitworth thread parallels, they look easier to use than wires but what is the correct way of use?
      #21821
      Michael Devlin
        @michaeldevlin84947
        #147923
        chris stephens
          @chrisstephens63393
          Hi Gray,
          I am glad you posted this as I bought a set of metric ones on Saturday for a tenner and now I know I know how to use them. No plastic clips but I am sure that is not an insurmountable problem.
          chriStephens
          #147968
          chris stephens
            @chrisstephens63393
            What ho Gray,
            That's the beauty of Google, your post came up about the use of the parallels. It also gives the current makers price list, including the plastic bits. I don't however expect them to sell many parallels at their present mega rip off price.
            There is a better way than three wire, single wire. Wrap a bit of copper wire, of the right diameter, around the thread pull tight and then measure. Copper wire comes in the same gauges as the three wire wire.
            Just so you know not to look, my visage will most likely appear in the next Journal, they gave me an award.
            ATB
            chriStephens
            #148004
            chris stephens
              @chrisstephens63393
              Sir, You flatter me, but I should warn you flattery will get you nowhere, I'm too used to itwink
              chriStephens
              PS it wasn't just one (puffs out chest with pride, or is that embarrassment )
              #248548
              Nobby
                @nobby
                Hi Guy's
                Has anybody got or know where I can find the tables for the MARLCO Whitworth set of measuring parallels
                Regards Nobby
                #248552
                  chris stephens
                    @chrisstephens63393
                    Hi Nobby,
                    MichaelG's answer gives all that is needed to operate the parallels, but if you are looking for "effective diameter" figures Machinery Handbook, Zeus or mdmetric.com/thddata.htm (where it is called pitch diameter.) will give all you need to know.
                    If you have digital calipers or Mic, measure the two parallels, reset zero and then measure with the thread between them, the figure on the digital reading will be the pitch/effective diameter directly with no need for any maths.
                    Hope this helps
                    chriStephens
                    #248561
                    Nobby
                      @nobby
                      Hi Chris & Michael
                      Thank you both for the info It helps a great deal .
                      Regards Nobby
