Marking out frames
Marking out frames
Home › Forums › Beginners questions › Marking out frames
  • #80366
    Eric Cox
      @ericcox50497
      When marking out frames, what is the best way to mark a radius when the centre falls outside the frames.
      #5807
      Eric Cox
        @ericcox50497
        #80368
          Clamp the frame and a bit of similar thickness scrap metal down to the bench etc and mark the centre in the scrap, dot punch and mark your arc.
          You could also use the other frame as the scrap just putting teh punch mark in a bit that will be cut away later.
          J
          #80369
          Brian Dickinson 2
            @briandickinson2
            Not an answer to your question but, i was in Poundland yesterday and they have some meter steel rules for, yes a quid.
            I opened one and had a look down its length and they look pretty good
