Making Parallels
Making Parallels
Home Forums General Questions Making Parallels
Viewing 25 posts - 1 through 25 (of 43 total)
  • #357757
    Alan Johnson 7
      @alanjohnson7
      I am sure I have read in an old copy in MEW an article, or part of an article, about shop made parallels, but I can't find a reference in the search engine about this. Can anyone help me find it please. regards, Alan.
      Alan Johnson 7
        @alanjohnson7
        #357760
        fishy-steve
          @fishy-steve
          From Harold Halls index. Edition 13 page 34. Also edition 237 page 48.
          I haven't checked if this info is correct though.
          Steve.
          #357766
          john fletcher 1
            @johnfletcher1
            Relating to the above, how parallel are new pieces of tool steel as used for lathe tools, as that is what I use, but never had any practical means of test them for accuracy. Never had any reason to complain as they seem to work OK for what I do.John
            #357771
            Thor 🇳🇴
              @thor
              Hi Alan,
              I have made parallels following Harold Hall's description, I just used mild steel but they have worked well. I assume that proper parallels ( hardened and ground) would have better accuracy, but my homemade ones have done the job so far. I also use races from old, dismantled ball bearings.
              Thor
              #357772
              Vic
                @vic
                No idea John but I’ve been using a couple of pieces of ground flat stock cut from the same bar and that seems to work well.
                #357773
                pgk pgk
                  @pgkpgk17461
                  Posted by Alan Johnson 7 on 14/06/2018 15:17:51:
                  All of our ground flat stock is supplied to the following standard tolerances:-
                  Thickness: +0.05mm/-0mm
                  Width: +0.2mm/-0mm
                  Length: +10mm/-0mm
                  An example.
                  No allegiance to this company but I have bought from them.
                  pgk
                  #357776
                  Mick B1
                    @mickb1
                    Posted by pgk pgk on 14/06/2018 17:23:46:
                    Width: +0.2mm/-0mm
                    Length: +10mm/-0mm
                    An example.
                    pgk
                    Does all that really matter? Even BDMS flats are good enough for most work. The actual width and thickness may typically be a a few thou down from nominal, but two pieces cut from the same bar are pretty unlikely to vary by more than a tenth or so. If you can't find any significant variation with – say – a Vernier mic reading tenths, it's likely to be good enough for almost anything.
                    #357780
                    John Haine
                      @johnhaine32865
                      Bearing races are useful but beware – they can have burrs on the edges. My mill table acquired a ring-shaped mark when I clamped something down on a race. The burr can be very faint and hard to feel but still mark as both the race and the table are very flat. Before using rub the face of the ring on a flat diamond lap or something similar.
                      #357781
                      Mike Poole
                        @mikepoole82104
                        I inherited a set of toolmaker made small parallels that are very useful. I think the thing that makes parallels expensive is not just that they are matched and parallel but also tightly controlled on size. Depending what you need them for the size may not be too important but they always need to be matched pretty well.
                        #357782
                        Alan Johnson 7
                          @alanjohnson7
                          Thank you all for your responses. I am glad that my memory "remembered" that I had read ………!
                          I do not need high acuracy, just need to repeat the production. Thin parallels are very good, but I just a bit too thin for what i am doing.
                          Thanks again,
                          Alan.
                          #357784
                          MW
                            @mw27036
                            I find what can be more useful (but more awkward to do) is to make a set of milling vice jaws that have a milled recess for a particular job. Seen lots of places do that.
                            Michael W
                            #357796
                            pgk pgk
                              @pgkpgk17461
                              Posted by Mick B1 on 14/06/2018 17:30:24:
                              Width: +0.2mm/-0mm
                              Length: +10mm/-0mm
                              An example.
                              pgk
                              Sorry – wrong quote… someone had asked how parallel are new pieces of tool steel. Ground stock should be more than adequate. As you state bright flats are probably better tolerance than the average home shop mill can dust a vice width component to but errors on errors won't help.
                              pgk
                              #357799
                              Ady1
                                @ady1
                                +1 for using lathe tool steel
                                #357845
                                Ian S C
                                  @iansc
                                  Old I laminations from a transformer.
                                  Ian S C
                                  #357863
                                  Hopper
                                    @hopper
                                    Pieces of key steel work well as parallels too. They seem to measure up as parallel as far as I can tell with a standard .001" resolution mike. Comes in a handy range of sizes. I even have some little 1/8" square ones to use in the little Myford vertical slide vice, up to 3/4" square for bigger jobs clamped directly to teh cross slide etc.
                                    And being made of slightly higher carbon steel than mild, and zinc plated, they seem reasonably durable and corrosion resistant. They seem to have more consistent sizing than HSS blanks too, which seem to vary a few thou from batch to batch or brand to brand.
                                    Edited By Hopper on 15/06/2018 13:28:46
                                    #357876
                                      Tool steel (I assume you mean HSS blanks) are normally accurately parallel, but are not necessarily accurately sized.
                                      #357898
                                      mechman48
                                        @mechman48
                                        Posted by Neil Wyatt on 15/06/2018 15:12:46:
                                        ​True Neil, I have various 'pairs' of HSS tool blanks that I use along with a set of thin parallels I bought. I have measured all & all are within .001", paired up, … ranging from 1/8" – 1/2" .
                                        George.
                                        #357913
                                        Nick Clarke 3
                                          @nickclarke3
                                          In an old ME article Tom Walshaw (Tubal Cain) suggests taking a large ball race from a car hub, nicking it in several places on the grinder, wrapping in sacking and hitting it with a hammer to make some parallels
                                          #357922
                                          mechman48
                                            @mechman48
                                            FYI, Have been & measured up the parallels mentioned above to give you some idea…
                                            ​As can be seen all are within .0005"… apart from the 1/8" pair where the difference is .0006"… close enough for my usage. Measured with Mitutoyo digi mic'… model # 293-766-10… accuracy to 0.0005" / 0.0127mm.
                                            George.
                                            Edited By mechman48 on 15/06/2018 17:48:27
                                            #481100
                                            andrew lyner
                                              @andrewlyner71257
                                              A bit of a 'necropst' but the thread is still relevant and answers several of my questions. This post is pretty relevant.
                                              There is one problem with the DIY approach and that is the need for a fair number of different pairs of stock to turn up in the limited selection I have in my shed. I already use two gash pairs and they are very handy but ti get work as deep as possible in the vise, I need more variety and that would mean ordering a number of different bits of stock – in steel – which could end up producing a lot of useless offcuts'
                                              I sort of came to the conclusion that buying a set of cheap parallels is the easiest solution. But the problem is, I have the 'right' sized vise for my mill – the 80mm Versatile Milling Vise from ArcEuro (Which is very good for my purposes). The 80mm chuck width doesn't really suit the parallels that I can find on line. They are all more than 100mm long and I have already found that my Sealy mill is much tinier than its appearance suggests. The shorter axis means that things get in the way and an overhang of parallels gives no significant extra support.
                                              So I am looking for some short ones (just a bit over 80mm. Can anyone point me at a supply? Anyone know of a source that's not Chronos, RDG, ArcEuro etc.? I guess there could be a far east s source but I don't know how to access it.
                                              I'm surprised that such a useful item for miini Mill owners is not on eBay (not for me, anyway.
                                              #481104
                                              old mart
                                                @oldmart
                                                I have loads of parallels in pairs, and they are essential for use with a mill, but have never used any with a lathe.
                                                The only way I can think of making any requires the use of a surface grinder, if you haven't got one just buy them ready made, new, or used.
                                                Edited By old mart on 20/06/2020 15:17:52
                                                #481114
                                                not done it yet
                                                  @notdoneityet
                                                  Posted by old mart on 20/06/2020 15:14:49:
                                                  Never ever needed to load a short, large diameter work-piece with clearance from the chuck face or to just protrude from the jaws? Easy with a couple of parallels.
                                                  #481122
                                                  Oven Man
                                                    @ovenman
                                                    Harold Halls book "Milling a complete course" has a chapter on making your own parallels. Seems to work quite well.
                                                    Peter
                                                    #481125
                                                    AdrianR
                                                      @adrianr18614
                                                      What a coincidence, This afternoon I started making my first pair following HH's book, then come in and see this thread for the first time.
                                                      Adrian
