Magnetic metal lids
Magnetic metal lids
Home › Forums › Beginners questions › Magnetic metal lids
  • #291776
    John Munroe
      @johnmunroe13164
      Hi all,
      I'm trying to make around 100 metal lids (50mm x 50mm) that are magnetic and have brushed finishes. It's a shame that aluminium isn't magnetic. Is stainless steel my only alternative? I try to keep it cheap and simple.
      Any thought appreciated.
      #8643
      John Munroe
        @johnmunroe13164
        #291778
          Posted by John Munroe on 02/04/2017 12:14:20:
          Hi all,
          You could, perhaps, make them out of Aluminium, then attach self adhesive Magnet strip.
          John Munroe
            @johnmunroe13164
            Posted by Michael Gilligan on 02/04/2017 12:17:33:
            Indeed. But I'm trying to make the whole lid magnetic whilst keeping the front and back a complete brushed finish.
            #291791
              Ah … a specific interpretation of 'lid' angel
              Looks like magnetic Stainless Steel might be your best choice.
              Anonymous
                "Cheap" ? Depends how magnetic you want it to be. The common stainless types are as good as non magnetic, from zero to slightly depending on how they have been worked. Would think the less common magnetic ferritic/martensitic types were more expensive
                #291818
                  You can put a brushed finish on mild steel do you need the non rusting properties of Stainless too?
                  #291819
                  John Munroe
                    @johnmunroe13164
                    Posted by JasonB on 02/04/2017 15:58:15:
                    Yes, I'd prefer it to have non-rusting properties as it may be exposed to some moisture.
                    #291821
                    Russell Eberhardt
                      @russelleberhardt48058
                      Mild steel and a coating of lacquer?
                      Russell
                      #291828
                      Ed Duffner
                        @edduffner79357
                        Nickel sheet can be purchased with a brushed finish and has slow corrosion properties.
                        Ed.
                        #291829
                        Keith Rogers 2
                          @keithrogers2
                          You can't magnetise Nickelsmiley
                          See OP.
                          Keith
                          #291833
                          Bazyle
                            @bazyle
                            Nickel is magnetic. That's why stainless is non magnetic. At atomic level the nickel magnets align to the iron magnets and neutralise them so to speak.
                            #291843
                            Keith Rogers 2
                              @keithrogers2
                              I apologise for that. Of course it is!
                              I was thinking of Nickel Silver which I believe isn't magnetic.
                              Keith
                              #291888
                              Russell Eberhardt
                                Posted by Ed Duffner on 02/04/2017 17:17:34:
                                Ed.
                                But the OP did say, "I try to keep it cheap and simple. " Nickel is not cheap, well it wasn't when I last bought some.
                                Russell.
                                #291893
                                  This may be of interest:
                                  [quote]
                                  Is stainless steel non-magnetic?
                                  It is commonly stated that “stainless steel is non-magnetic”. This is not strictly true and the real situation is rather more complicated. The degree of magnetic response or magnetic permeability is derived from the microstructure of the steel. A totally non-magnetic material has a relative magnetic permeability of 1. Austenitic structures are totally non-magnetic and so a 100% austenitic stainless steel would have a permeability of 1. In practice this is not achieved. There is always a small amount of ferrite and/or martensite in the steel and so permeability values are always above 1. Typical values for standard austenitic stainless steels can be in the order of 1.05 – 1.1. See Composition effects on the magnetic permeability of austenitic stainless steels
                                  It is possible for the magnetic permeability of austenitic steels to be changed during processing. For example, cold work and welding are liable to increase the amount of martensite and ferrite respectively in the steel. A familiar example is in a stainless steel sink where the flat drainer has little magnetic response whereas the pressed bowl has a higher response due to the formation of martensite particularly in the corners.
                                  In practical terms, austenitic stainless steels are used for “non-magnetic” applications, for example magnetic resonance imaging (MRI). In these cases, it is often necessary to agree a maximum magnetic permeability between customer and supplier. It can be as low as 1.004.
                                  Martensitic, ferritic, duplex and precipitation hardening steels are magnetic.
                                  [/quote]
                                  http://www.bssa.org.uk/faq.php?id=24
                                  Circlip
                                    @circlip
                                    And Martensitic "Stainless" steels, usually employed in the manufacture of high temperature fastenings WILL rust.
                                    Another non theoretical fact.
                                    Regards Ian
                                    #291943
                                    mark costello 1
                                      @markcostello1
                                      400 series SS is magnetic.
                                      #291945
                                      MW
                                        @mw27036
                                        Well given the large amount of iron that make up steels, it stands to reason that it would maintain some magnetic property even after the inclusion of non-ferrous elements.
                                        Michael W
                                        #291956
                                          Posted by Circlip on 03/04/2017 10:31:40:
                                          … but they do stain less than some other steels devil
                                          Rejoice in the subtlety of the English language
                                          [ Stainless doesn't necessarily mean unblemished or unblemishable. ]
                                            Posted by Michael Gilligan on 03/04/2017 19:03:33:
                                            Less as a suffix means 'without'.
                                            Wiktionary: "From Middle English -les, -leas, from Old English -lēas (“-less”), from lēas (“devoid of, loose from, false”), from Proto-Germanic *lausaz (“loose”). (Not related to less, which derives from *laisiz, *laisizô.)"
                                            This may leave me friendless and I know it's heartless of me to say so, but I must be fearless not gutless as your shameless sophistry generated a worthless posting, unlike your usual peerless contributions and tireless curation of our meaningless excursions into the boundless expanses of the English language.
                                            devil
                                            P.S. Please forgive
                                            #291977
                                              angel
                                              #291980
                                                I believe you admire Wikipedia, Neil … so please forgive me for supplying one brief quote therefrom, instead of fully documenting my argument
                                                Stainless steel does not readily corrode, rust or stain with water as ordinary steel does. However, it is not fully stain-proof …
                                                https://en.m.wikipedia.org/wiki/Stainless_steel
                                                … You will, I suspect, recognise the similarity with ShatterProof vs. Shatter-Resistant, as recently discussed.
                                                Edit: predictably … I can't just leave it at that, so see here:
                                                http://www.ancare.com/our-products/stainless-steel
                                                Edited By Michael Gilligan on 03/04/2017 21:59:42
                                                #291987
                                                  Posted by Neil Wyatt on 03/04/2017 20:32:41:
                                                  devil
                                                  P.S. Please forgive
                                                  Careless work Neil – surely 'Less is More' , ho ho.
                                                  #292019
                                                  John Haine
                                                    @johnhaine32865
                                                    Well, all our stainless steel kitchen knives fell off the magnetic rack as I was reading this thread….wink
                                                    The power of faith.
