Some idea of the application would help responders offer some remedial ideas.
If they are for panels in sheetmetal work, and only a few threads, there may be ways to use more available fasteners.
.75 mm pitch ( .0295" pitch) is very close to 34 tpi (.0294" )) . If you have a lathe than can cut 34 tpi you could make your own screws.
34 tpi (.0294" pitch) is close to 32 tpi (.0312" pitch) , only .0017" difference in 32 to 34 pitch, and 4.0 dia is .157". A stock #8-32 machine screw is .164 dia x 32 tpi. If not too many engaged threads are involved you could probably overtap the holes (if tapped) #8-32 and use #8-32 screws which are widely available in many materials, lengths, and head styles.
You could probably overtap the holes (if tapped) M4 x 0.7 and use M4 std screws, again if not too much thread engagement is needed. M4 are also available in lots of materials lengths and head styles.
If you can find some 3BA screws you could probably use them although their pitch is nominally 0.73mm not 0.75 so if there are a lot of engaged threads the screws might jam.
If you ever need to replace the screws in future years you might be glad you used #8-32 or M4 x 0.7 – BA screws are less and less available, it seems.
Edited By Jeff Dayman on 22/08/2019 21:09:18
Edited By Jeff Dayman on 22/08/2019 21:09:36
Edited By Jeff Dayman on 22/08/2019 21:11:54
