Lever collet closer problem
Home Forums General Questions Lever collet closer problem
  • #555731
    Gavlar
      @gavlar
      I've have a lever collet closer and collets that I will never use. (I have ER collets and holders for everything!)
      I thought I'd check it out before passing it on so mounted it on my AUD.
      Everything looks ok and moves freely but the collet doesn't close and I can't work out why. The fulcrum is anchored and the lever moves freely but I can't see what it's supposed to move to close the collet.
      I strongly suspect user error!!
      I've uploaded an album with photos.
      model-engineer.co.uk/forums/new_thread.asp?t=162
      Thanks for any advice, Gavin.
      Edited By Gavlar on 26/07/2021 07:55:16
      #28272
      Gavlar
        @gavlar
        #555794
        Gavlar
          @gavlar
          Cracked it, user error as I suspected.
          #555811
          Clive Foster
            @clivefoster55965
            Gavlar
            What were you doing wrong?
            I have a similar device that I might actually get round to using one day. Be nice to know how to set it up to close. Looking at It I don't properly see how it all goes. One reason why I've stuck to the screw tube operated by a handwheel at the back system.
            #556099
            Gavlar
              @gavlar
              I was expecting too much movement in the collet. I assumed the lever would take the collet through it's full range, which with Burnerd collets is around 120 thou. The lever only closes the collet the last few thou so I couldn't see it. Simply placing the workpiece in the collet, tightening it by hand then backing of a half turn, allowed the lever to do the rest.
