Posted by Muzzer on 24/06/2017 13:51:55:
Just about any ISO32 oil will do – it's the official modern replacement. It's a fairly low viscosity oil and is usually described as hydraulic oil so readily available at motor factors in 1 gallon or more. Or on ebay.
If you buy it as hydraulic oil in 1 litre bottles at Halfords you will pay through the nose (£10 per litre?). No need to play about with engine oils which contain all sorts of unnecessary additives.
The same Tellus 27 / ISO32 is also specified for lubricating the ways and oiling points, so you may as well get a gallon or more of the stuff.
Murray
+1.
EXACTLY wot he said. Just buy a gallon (5 liter) can of hydraulic ISO32 w oil. Cheap as chips at a large commercial auto parts handler. You will go through the stuff if you lube everything with it inc ways etc.
Do NOT waste money on small bottles of the above, nor buy any engine or transmission oils.
