Jerry… Good choice
I have put down a few pointers for you when you get your machine; other members may have different items to offer, but these are what I found on my machine, 250V-F.
Check the electrics when you get it; the two main problems I found were that the change gear guard has a tab on the bottom at the back (250V-F, other machines may have it placed elsewhere), this tab contacts and operates a micro switch for the motor cut out, this tab had been bent away from the switch making it unable to start… frustrating when still in the box! The other item is check the locking collar on the emergency stop button, this is secured (on mine) by a screw acting on the locking bracket & jacking the bracket against the top of the electrical compartment casing & pulling the button down against the casing top, this had the effect of allowing the button to rotate loosely which then had dislodged one of the wires from the button hence … no workee… scratchee head… along with a lot of ‘oh dear me’ ‘tut tut’, or words to that effect!… & supposedly checked by Warcos Engineers… ?
Check all the fastenings on the machine; SHCS & bolts, these are made from the Chinese basic steel… crap!
The SHCS / Hex head bolts are stamped 4.2 which is lower tensile strength than the minimum BS3692 of 4.6… in other words ‘soft as s**t! so it doesn’t take much torque to strip threads… trust me I know! Especially the two compound slide T bolts that hold the compound slide to the cross slide, on mine I found these to have stripped very soon after a couple of angle settings on the compound, & not tightened to any excess (subjective I know!) merely snugged up. I replaced these with a couple of 8.8 grade bolts & fabricated some proper ‘T’ nuts from decent steel… EN8 IIRC. plus they were short in length stopping short of the full nut so I ensured that my replacements went down into the ‘T’ nut full length.
The change wheel gears are noisy, this was due to the backlash being incorrectly set up, (don’t think the manufacturers know what this is) I set mine up using the ‘paper method’ (which it seems a few members have used). All it needs is to place a piece of paper, which is generally about .004” thick between the meshing teeth & adjusting the banjo to nip the paper, do this with each gear mesh. The other factor is there is a lot of slop … on mine… between the ID of the gear bore & the OD of the matching banjo shaft. I am looking to reduce this by some means later on, bushings, new shafts?
Adjust your gib strips as these are made from the above mentioned steel, not cast iron, & are just strips of plate with the angles somewhat ground on & they don’t ensure that the gib screws fit, it seems that their idea of dimples is to ram a pistol drill down the tapped hole irrespective of the strip being in the correct location or centralised, followed by three or four black SHCS with lock nuts on. I will replace these later if I can get hold of some thin enough CI, or poss’ Phos’ Bronze/ Brass
Hopefully you get a machine that has had better quality control applied, never the less now I have tweaked, adjusted, replaced etc. I have a very reasonable ‘hobby machine’ that does what I have thrown at it, after all, ‘you don’t get a rolls for the price of a mini’, other members may /may not have had similar issues, so I assume they may offer additional tips, anyhow the main point is … ‘enjoy’
Cheers
George
