lathe ,and er32 collet …
Home › Forums › Beginners questions › lathe ,and er32 collet …
  • #246989
    zuji miko
      @zujimiko33021
      which one is ok .for smaller peaces ?
      http://chronos.ltd.uk/acatalog/ER32-Collet-Chucks—Collets-for-Lathe-Mounting.html
      or one of these
      http://www.rdgtools.co.uk/acatalog/ER32_SPRING_COLLET_CHUCK_SYSTEMS.html
      2-20mm range ,but how to mount it …. they sell only collet chucks ..
      #8215
      zuji miko
        @zujimiko33021
        #246992
          The RDG one is placed into the lathes spindle taper and pulled in using a drawbar, this has the disadvantage of not allowing long pieces of work to be held.
          The Chronos one fits onto a backplate that you will have to buy separately and machine but you can fit long work into it.
          #246993
          Tim Stevens
            @timstevens64731
            Against the problem of coping with long work, the taper fitting (your RDG version) is quicker to set up, as concentricity is (almost) guaranteed.
            But do remember that both these ER collet holders are available from a range of suppliers, not just the two you mention.
            Cheers, Tim
            #246994
            Bob Brown 1
              @bobbrown1
              #246995
                Interesting thought Tim, I would have said that the backplate one can be fine tuned when first fitted to the backplate to give very good concentricity and that will remain whenever the chuck is fitted. The MT version is only as good as it is made and can't easily be fine tuned if it is found to be lacking.
