Lammas hardness tester
Home › Forums › General Questions › Lammas hardness tester
  • #251107
    Piet Vermaat
      @pietvermaat68506
      Rod Jenkins wrote about the construction of the Lammas hardness tester in MEW no 245. He mentions a double lever multiplying the force 24 x.
      Could someone please explain how that works?
      Thanks.
      PV
      #24688
      Piet Vermaat
        @pietvermaat68506
        double lever system
        #251111
        Brian Wood
          @brianwood45127
          Hello Piet,
          ​I don't know the specifics with this design, but it is very probably the same as the method used on hardness testers generally.
          In those, it is quite simply the effects of leverage of a weight, in this case of 5 kg, acting on a pivoted bar with a ratio of 24:1 from the fulcrum point. The known weight (5kg) is at the long end of the bar and the ratio multiplies its effect at the shorter end by 24 times
          Regards Brian
          #251122
          Roderick Jenkins
            @roderickjenkins93242
            Piet,
            Here is a diagram of the mechanism
            The first lever gives a 3x multiplication of the force to 15kg. The second lever has a 8:1 ratio so multiplies the 15kg x 8 to give a force at the indentor of 120kg.
            Hope this helps,
            Rod
            #251178
            Piet Vermaat
              @pietvermaat68506
              Thank you Brian and Roderick for the explanation.
              PV
