Keyless chuck so tight can get hole way out
Home › Forums › Beginners questions › Keyless chuck so tight can get hole way out
  • #289115
    petro1head
      @petro1head
      I used a hole saw in my keyless chuck, now its so tight I cant get it out,
      Any ideas that do not involve a hammer
      #8617
      petro1head
        @petro1head
        #289116
        Jon Gibbs
          @jongibbs59756
          Have you tried a strap wrench around the chuck body?
          #289117
          richardandtracy
            @richardandtracy
            Angle grinder? Not a hammer… crook
            The other thought is a stilson or chain wrench, water pump pliars, mole grip, something where it grips hard and you do the twist.
            Richard
            #289122
            Senior Yates
              @senioryates
              Carver clamps always made good chuck keys when I worked in the Toolroom smiley
              #289123
              Peter Krogh
                @peterkrogh76576
                Drill a hole through a piece of wood, that is as thick as where you want to grip or more, a bit smaller than the grip area. Then saw the piece longways through the center of the hole. Now you can grip the chuck in a vise without damaging the chuck!
                Pete
                #289125
                petro1head
                  @petro1head
                  Thanks
                  I found this which worked, shap tap with a copper mallet and it freed. This has put me off keyless chucks tho.
                  http://www.pistonheads.com/gassing/topic.asp?t=969082
                  Edited By petro1head on 16/03/2017 17:20:03
                  #289134
                  Brian Oldford
                    @brianoldford70365
                    Percussive maintenance works well most times.
                    #289137
                    petro1head
                      @petro1head
                      Posted by petro1head on 16/03/2017 15:44:25:
                      Indeed, I knew I bought that copper hammer for a reason
                      Edited By petro1head on 16/03/2017 18:47:20
                      #289141
                        Posted by petro1head on 16/03/2017 17:19:01:
                        Don't let it put you off them but bear in mind that most of them will tighten when loaded. A large dia holesaw has quite a bit of leverage so will make the jaws tighten up. Also if your saw arbor was hexagonal as most are it will just keep putting more load onto the jaws whereas a drill bit will spin in the jaws.
                        #289145
                        petro1head
                          @petro1head
                          I did wonder about the arbor being hex and the saw teeth putting quite a load on the chuck
                          #289255
                          Grizzly bear
                            @grizzlybear
                            Slightly O.T.
                            I have a Clarke Metal Worker drill press, always had bother with the keyed chuck, lack of grip.
                            Since reading the posts about using all the positions to tighten the chuck, its been fine. Thank you.
                            Bear..
