John Wilding Regulator
Home › Forums › Clocks and Scientific Instruments › John Wilding Regulator
Viewing 25 posts - 1 through 25 (of 68 total)
  • #125602
    Russell Eberhardt
      @russelleberhardt48058
      Hi
      I have just received the book and intend to have a go at making the month going version. Has anyone else here made one – any hints or tips.
      I am intending to make a few modifications:
      First I'll fit ball bearings to all the pivots. Modern miniature ball bearings have very low friction, even lower than jeweled bearings. I intend to fit them in eccentric bushes to enable the meshing of the pinions/wheels to be adjusted by a few thou. Something like this:
      That should eliminate a problem I had with my skeleton clock where I had to bush and re-drill one of the pivot holes where the meshing was too tight.
      The second proposed modification is to replace the one piece pallet assembly with the adjustable type of pallet frame with separate pallet nibs.
      I'd appreciate any comments on these modifications.
      Russell.
      #3668
      Russell Eberhardt
        #125604
        Stephen Benson
          @stephenbenson75261
          Hi Russel, your mods sound OK I would only add that I would guess that you would want your clock to be running long after you are gone so please think of future repairers. I often get to repair Longcase clocks that are 200- 300 years old and they can be kept running indefinitely, will a repairer be able to find the right ball bearings in 300 years?
          There is a lot more skill involved using traditional methods but there will always be people able to repair your clock.
          Steve
          #125608
          roy entwistle
            @royentwistle24699
            I understood that ball bearings do not like sudden starting and stopping I believe the races get pitted
            perhaps someone else can confirm ordeny this I have made several clocks and stick to traditional clockmaking wherever i can though I must confess to using locktite to fasten wheels and pinnion to arbours
            Roy
            #125641
            Russell Eberhardt
              Thanks for your replies. I found an interesting paper on the use of ball bearings here:
              In that paper he has measured the friction in a ball bearing pivot to be about 70 times less than a conventional pivot. He has also calculated that the life of the bearings he has fitted to his clock works out at between 11,000 and 31,000 years although he does point out that the calculations may not be wholly valid at this extreme. Replacement is unlikely to be needed for a considerable time and I suspect by then they will be using totally different bearings which could be fitted and have even less friction.
              I too have seen comments that ball races don't like intermittent motion, I can't find any references to any tests having been performed. However I doubt it will be a problem with our very light loading.
              One more question: Does anyone know which give the best performance, cut pinions or lantern pinions? I guess it's easier to get a good finish on the working surfaces of the latter.
              Russell.
              #125648
              roy entwistle
                @royentwistle24699
                If the wheels and pinions are depthed correctly there won't be much difference between solid pinions and lanterns Lanterns do allow debris to fall through
                I personally would not use ball races at the top end of the train you are adding extra weight where you least need it
                Roy
                #125654
                Stephen Benson
                  @stephenbenson75261
                  I am a Mechanical Engineer and now a Clockmaker making my first clock I used my Downham Jig Borer, Cowells Lathe and made everything to very close tolerances so my clock had no chance of running properly or in fact at all.
                  When asked I always say never get a engineer to repair your clock as they will be horrified by the fit of pinions in the holes etc etc and they will want to "improve it" you have to repair a lot of clocks before you get a feel for what is important but there is a saying in the Clock trade if it rattles it will run.
                  Best of luck with your improved clock I am sure you will learn a lot..
                  Edited By Stephen Benson on 29/07/2013 13:39:10
                  #125655
                  macmarch
                    @macmarch
                    I'll go with that. As an engineer of more years than I like to remember, the 'fit' of pivots in holes and meshing of gear teeth in clocks is horrifying. However, if you think about the almost non-existent power impulse from the escapement wheel to the pendulum, then even ceramic bearings have a bigger rolling resistance, per ball, than the impulse power, add some lubrication and its even worse. As in locomotive building, if the axle bearings rattle then it will run forever.
                    I'm relatively new to building clocks but as I understand it, pinions mesh with involute teeth and lanterns mesh with triangular teeth.
                    #125656
                    Russell Eberhardt
                      Posted by roy entwistle on 29/07/2013 12:49:19:
                      Thanks Roy,
                      I'll probably go for solid pinions then. I'll buy them in as it's cheaper than buying the cutters.
                      I didn't think that the weight of the escape wheel assembly was important. It's the moment of inertia that is important due to the stop/start motion. The moment of inertia is the sum of M x (R x R) so weight near the centre of rotation is much less important than that near the edge. However every bit helps so I'll use the smallest ball bearing I can find, 1mm ID x 3mm OD should do it.
                      Russell.
                      #125657
                      Russell Eberhardt
                        Posted by Stephen Benson on 29/07/2013 13:35:14:
                        Thanks, I may need the luck!
                        I made the same mistake as you with my first clock and had to take it apart and open up all the pivot holes to make it more rattly. It now runs well keeping time to about a minute a week. I'm hoping for nearer a second a week with this one.
                        Russell.
                        #125658
                        Stephen Benson
                          @stephenbenson75261
                          Hi Russell,
                          I like lantern pinions they are just as good as solid pinions and they are much easier to make, I use them in all my clocks with normal horological tooth form.
                          Steve
                          #125716
                          Russell Eberhardt
                            Hi Steve,
                            I have now read that lantern pinions give less friction than solid ones when being driven by the wheels and more friction the other way round. Don't know if this is true or not – must do some more research.
                            Do you know the correct relationship between wire size and module? I cant seem to find that in any of my books.
                            Russell.
                            #125742
                            roy entwistle
                              @royentwistle24699
                              Try the pinion wire in between two wheel teeth it should slip in between plus a little clearance
                              Roy
                              #125744
                              Stephen Benson
                                @stephenbenson75261
                                Posted by Russell Eberhardt on 30/07/2013 07:47:47:
                                Hi Steve,
                                Russell.
                                In answer to your first question you are quite correct they should not be used to drive a gear and they do give less friction in fact a 8 pin lantern has about the same friction and 10 tooth solid pinion. However most Horologists agree including John Wilding that it is perfectly OK to use a lantern pinion to drive the hour wheel in the motion work, this is what I have done to good success on my clocks I would post a picture but they make it so difficult on this forum to post pictures that I do not bother any more.
                                Roy has answered your second question perfectly
                                #125786
                                Peter Bell
                                  @peterbell11509
                                  Hi Russel,
                                  I started making the John Wilding regulator in 1988 and by 1990 had it running reasonably well but it was never very reliable as I was unable to make the pallets work to my satisfaction in spite of making 3 sets. I found them very difficult to set out etc with my knowledge at the time so the project was shelved.
                                  Reading over the years I decided that Vulliamy style pallets as used by C B Reeve in many of his clocks looked a good option and thanks to CAD I now understand how to lay them out and with my Siege KX3 have managed to machine the arms and nibs. These are only semi finished at present but tests with these on the depthing tool look good and I look forward to progressing further soon.
                                  I have read the ball bearing debate over the years and note that a number of "top end" commercial clocks use these and hope to fit these to the regulator after I prove the pallets. I am also constructing a C B Reeve gravity regulator using ball races and although it is not yet running the train will free wheel for far longer that any conventional bushed movement I have seen, and thats before the grease is washed out. I plan to use ceramic balls eventually. I find that small ball races are easy to damage especially if the housings are tight but they are cheap and readily available and I would be surprised if the standard metric sizes used become unavailable over the years.
                                  Good luck with the regulator, look forward to hearing of your progress.
                                  Peter
                                  #125799
                                  roy entwistle
                                    @royentwistle24699
                                    I can't see why you had to make 3 sets of pallets They are not as complicated as some of the apprentice pieces we had to make 65 years ago My first set were made using a hacksaw and ffiles they still work 20 years on The last couple I've made using a piercing saw and a couple of swiss files after they have been proved in the clock I harden them glass hard All my palets are made in guage plate
                                    Best of luck Roy
                                    #125803
                                    Ian S C
                                      @iansc
                                      If in many years the bearings fail, and can't be replaced, you could always go back to plain bearings by fitting bushes in place of the ball races. Ian S C
                                      #125809
                                      NJH
                                        @njh
                                        How nice to have a discussion on clockmaking for a change!
                                        I too am attracted to John Wilding's regulator, have the book and bought most of the materials some years ago. We have since moved to a very nice modern house – lots of windows and doors 7ft 6in ceiling height – doesn't really lend itself to a longcase clock! I have also made all the bits for Wildings 8 day wall clock which I intended to put into a longcase. My daughter now lives in an old cottage and her partner is a very skilled (but busy) woodworker so, if I can pursuade him to make a case, I will put it all together and give it to them.
                                        Please keep posting details ( and some photos perhaps?) of your progress on this project.
                                        Best wishes
                                        Norman
                                        #125822
                                        Stephen Benson
                                          @stephenbenson75261
                                          The WIlding regulator has a dead beat escapement and you really need to understand the action to make a good job as they need four faces to be perfectly aligned to work well.
                                          The Wilding 8 Day Wall clock has recoil escapement which only works on two faces it is very tolerant of errors and as it is weight driven it will keep time to 30 seconds a week or better if you add a simple maintaining power mechanism.
                                          Both will go into a long case but Wilding has updated the recoil 8 day wall clock to make it even more interesting with an amazing perpetual calendar and a normal one also a very interesting striking mechanism using the single 10 pound weight plenty to keep the average model maker or clock maker happy with all most no repetition.
                                          I think you can guess which one I am doing.
                                          Steve
                                          Edited By Stephen Benson on 31/07/2013 18:20:52
                                          #125826
                                          MICHAEL WILLIAMS
                                            @michaelwilliams41215
                                            (1)
                                            The rattling fit beloved of clockmakers is actually good engineering practice not the opposite . Given the set of running conditions existing at pivots in clocks a loose fit is what a design engineer would choose .
                                            Motion in most clocks is intermittent tick – pause – tick – pause ad infinitum . As each tick is initiated the small amount of force available has to ' unstick ' the pivot journal in its bearing before any actual movement can occur . Simple turning to unstick requires relatively a large force but clockmakers must have realised very early on that if the bearing is a little oversize then the pivot journal can begin its motion with a minute ' epicyclic ' type roll – which requires relatively a small force – before beginning main part of motion .
                                            This situation is very similar to the one which exists where O rings are put in elongated grooves in pistons so as to reduce starting force and stiction effects ..
                                            A secondary reason for making clock bearings slightly oversize is to improve dirt tolerance .
                                            For the clock in general making engagement fits consistently loose everywhere improves the tolerance of the clock to random wear in the working parts over many years .
                                            (2)
                                            Ball bearings only have lower friction values relative to plain journal bearings of similar size when both are new and clean . Given any accumulation of atmospheric dust and goo the ball bearing rapidly stiffens up whereas the plain journal bearing is much more tolerant .
                                            (3) Just on the basis of gearing theory it would seem at first glance that a clock wheel to engage a lantern pinion should have different tooth profile to a clockwheel engaging a conventional toothed pinion .
                                            (4) Just out of interest – there are many applications in the aerospace industry where components in an assembly are a rattling fit when the assembly is in cold / static condition . Looseness may be designed in to allow guaranteed freedom of motion under very harsh working conditions or alternatively designed to take up under working conditions to give normal running clearances .
                                            MikeW
                                            Edited By MICHAEL WILLIAMS on 31/07/2013 19:21:50
                                            #125834
                                            JA
                                              @ja
                                              I think I have got this right – There was a amateur clock maker that designed and made a number of advanced mechanical clocks that featured in the journal of the British Horological Institute. One of these clocks was a year clock with a titanium escapement wheel. He recorded that his introduction to clock making was the Wilding 8 day regulator which he never got to work properly.
                                              My attempt with the Wilding regulator sits on the shelf in the workshop. It has never run successfully. If I knew then what I know now I would have opted for an anchor escapement clock. Deadbeat escapements are very good time keepers but there is more to clocks than timekeeping. With an anchor escapement you can ring bells and do all sorts of things.
                                              JA
                                              #125835
                                                JA,
                                                I don't think this one was year-going, but it may be of interest
                                                Search the page for Titanium …
                                                Series by Richard Stephen
                                                roy entwistle
                                                  @royentwistle24699
                                                  J A Don't give up with your regulator if you find the Graham Dead Beat escapemet too difficult there's nothing wrong with using an Anchor it might not be correct but at least youv'e got a clock
                                                  I find with my regulatoe that the " Invar " steel pendulum rod contracts with warmth and expands with cold Any ideas ?
                                                  Roy
                                                  #125843
                                                    Posted by roy entwistle on 31/07/2013 21:26:01:
                                                    Roy
                                                    Roy,
                                                    Two thoughts …
                                                    1. Invar is not quite so accurate, or so stable, as one might wish
                                                    2. It could be that the Pendulum Bob is "over-compensating"
                                                    Edited By Michael Gilligan on 31/07/2013 21:48:43
                                                    #125861
                                                    JA
                                                      @ja
                                                      I may dig out the clock this winter and continue work on it. I had not thought about using an Anchor escapement (the geometry of the pivot holes may have to be changed radically) but first I will loosen up the pivots and possibly rebush one.
                                                      I will try to give an up-date in a few months.
                                                      JA
