Is this scrap?
Is this scrap?
Home › Forums › Beginners questions › Is this scrap?
  • #5921
    Wolfie
      @wolfie
      #83846
      Wolfie
        @wolfie
        I reckon I’ve killed this slitting saw is there any point in trying to sharpen it or do I chuck it.
        Not quite sure how I did it, maybe running too fast?
        #83849
        jason udall
          @jasonudall57142
          you never know.
          They can be sharpened but not realy at home unless you need a new hobby…3*3.142*tpi teeth and hss..
          Cost of regrind prob. exceeds cost of new saw..
          But steel might be handy as “washer”
          #83851
          Richard Parsons
            @richardparsons61721
            No get a little “3 square” emery stone or a diamond file and one day start to sharpen it. It will do a ‘turn’ when you need it.
            Good practice
            Rdgs
            Dick
            #83852
            jason udall
              @jasonudall57142
              like I say … new hobby
              #83854
                You do need to run them quite slow, probably as slow as your little mill will go and use suitable cutting fluid for the material being cut.
                One other thing if you were using that 1.0mm saw to try and do your clevis you will find that as the slot can’t be done with one cut that the saw will tend to deflect into the previous saw Kerf. You really want a specific blade width for each likely slot eg, 1/16, 3/32 & 1/8 and the same if you work in metric 1, 2 & 3mm
                J
                #83859
                John Stevenson 1
                  @johnstevenson1
                  Ideal speed for slitting saws is as slow as you can go, then halve it
                  Don’t care what any tables say I’d run a 3″ saw at 80 revs max in steel with loads of cutting oil.
                  And NEVER use the key to secure it, first time it hangs up instead of slipping the key will split and shatter the saw and you will end up wearing it.
                  John S.
                  #83871
                  Sub Mandrel
                    @submandrel
                    The ‘building the quorn’ book explains how to sharpen slitting saws.
                    It’s not that hard really as gthere is no relief, you just need a wheel with a good corner to get into the tooth space and grind the front of each tooth back to its original profile.
                    You wpould have to make some sort of holder for the blade, but indexing is easy – just use a bit of springy metal against a tooth and after you sharpen each tooth click around to the next.
                      @nousername29627
                      Life is too short to sharpen slitting saws!
                      #83938
                      Russell Eberhardt
                        @russelleberhardt48058
                        Harold Hall published a design for a jig (or is it a fixture?) for sharpening slitting saws on his grinding rest. I have built one and it only takes a few minutes to sharpen the saw while it takes several days to get a new one sent mail order!
                        Most small mills run the spindle much too fast on their lowest speed for using a slitting saw. That was my initial reason for fitting a variable speed drive.
                        Russell.
                        #83941
                        Terryd
                          @terryd72465
                          Posted by russell eberhardt on 05/02/2012 14:08:11:
                          Russell.
                          Hi Russell,
                          According to Wikipedia it is a jig. Apparently the difference is that a fixture secures items for working on while a jig controls the tool as well, so Harold Halls device holds the workpiece and effectively guides the tool (although you move the work against it but you could arrange the grinder to move to the jig) so it must be a jig. We used to build welding fixtures for manual welding (I wasn’t involved) and of course the welder controls the tool, while the jigs we made for the motor industry held panels for welding with fixed spot welders, effectively the tools were controlled by the jig.
                          Terry
                          #83945
                          Terryd
                            @terryd72465
                            Posted by Wolfie on 04/02/2012 17:43:31:
                            Hi Wolfie,
                            You could cut it into strips with a thin cutting disc and have a supply of HSS thin parting tools .
                            I agree with others that it is speed that kills with these.  Also as John S said never use the key slot to secure it.  Don’t bin it, keep it ’til you build HH’s Grinding rest and the saw sharpening jig.
                            Best regards
                            Terry
                            Edited By Terryd on 05/02/2012 15:05:49
                            #83946
                            John Stevenson 1
                              @johnstevenson1
                              The correct way to grind slitting saws is to grind every alternate tooth in the same direction then either reverse the wheel or swap the saw over and do the other teeth in the other direction.
                              The idea is the burrs thrown up by grinding give some clearance. Same for cutters with clearance teeth, always throw the burrs off the edge, not onto the cutter.
                              John S.
                              #83949
                              Terryd
                                @terryd72465
                                Hi John,
                                Thanks for that tip. I’ll remember it when I have one to do.  There’s always something to learn.
                                Best regards
                                terry
                                Edited By Terryd on 05/02/2012 16:11:31
                                #83951
                                Anonymous
                                  Bin it! The saw is pretty fine pitch; that’s fine (!) for slotting screw heads, but not much use for anything else. For any decent depth of cut you’ll need a much coarser tooth pitch so that the gullet (space between teeth) is bigger so the swarf won’t jam the saw.
                                  #83967
                                  chris stephens
                                    @chrisstephens63393
                                    “Bin it” BIN IT are you mad, they cost money you know.
                                    It can easily be sharpened , admittedly if you have the kit, and converted to a deeper gullet coarser blade at the same time. The only time you bin a blade is if you completely c*cked up and shattered it. Even then, as has been suggested, you can use the steel for other things.
                                    All you “bin it” people must be youngsters and be infected with the modern virus called “throwawayage”.
                                    chriStephens
                                    #84025
                                      @nousername29627
                                      No – I am not a youngster but I value my time and the older you get the more you realize how limited and valuable it is. I certainly do NOT waste it by sharpening slitting saws, hacksaw blades, centre drills, end mills (all explained in the Quorn book) or even drills under 1/8. Settig up the grinder, jig, fixture or whatever you use takes far too long – just try setting up the quorn and sharpening the ends of the teeth and the helix and see how long it takes”and unless you have an air spindle the results are suspect at best.
                                      STOP WASTING TIME!
                                      #84030
                                      chris stephens
                                        @chrisstephens63393
                                        Talk about wasting time, make yourself a stationary engine and have it sit on
                                        the mantle shelf doing nothing except collect dust, but make yourself some tooling
                                        and you have something really useful.
                                        chriStephens (tongue firmly in cheek)
                                        PS Yup, Quorn not as easy to set up as one would hope, but it makes another excuse for fiddling with tooling in an effort to improve it.
                                        #84062
                                        Anonymous
                                          Posted by chris stephens on 05/02/2012 19:26:59:
                                          “Bin it” BIN IT are you mad….
                                          Yes; why on earth would I want to be sane in a crazy world?
                                          #84072
                                          Sub Mandrel
                                            @submandrel
                                            Posted by Andrew Johnston on 06/02/2012 20:13:40:
                                            He could keep them for shuriken, if he ever decides to become a ninja.
                                            Actually, I was quite impressed by the thin parting tool idea.
                                            Harold Hall 1
                                              @haroldhall1
                                              Have a look here Wolfie
                                              If a saucer wheel were available then the other face could be ground, first sharpening every other tooth, reversing, then the missed teeth, as John S suggests. Larger tooth saws are of course easier to sharpen.
                                              Harold
                                              #84084
                                              chris stephens
                                                @chrisstephens63393
                                                Or sharpen every other tooth but much deeper increasing the gullet size and halving the number of teeth, which will make it more useful.
                                                chriStephens
