What a lot of replies! Thank you everyone.
Firstly my humble apologies – I got confused about my "new-ness". (In my defence, I hadn't used the site for a fair while and for some reason I simply couldn't find where to see any of my previous posts!)
MY REQUIREMENTS
To get clear, here are my IDEAL requirements for what I am looking for an adhesive tape:
a. Forms a strong permanent bond (is not removable, resists a strong constant pull well)
b. Is highly flexible (so would form a good hinge)
c. Is transparent (or better yet, "invisible" like 3M's Magic Tape – but that doesn't age well)
d. Ages well:
– Won't discolour
– nor go rigid
– nor crack over time
e. Resists heat well
f. Bonds well to a variety of materials, but particularly to styrene and ABS.
g. Is single-sided (although double-sided could also be of interest at some point too)
h. Is pretty thin (much like Sellotape – although thicker versions could be if interest at some point too)
i. Is extremely flexible (so many thousands of open-shut cycles won't be a problem)
j. (if possible) is dead-easy to apply (as is Sellotape),
– Nothing to measure out in equal quantities
– Nothing to stir
– No separate adhesive to apply
– No special equipment (e.g. no irons needed!)
k. (if possible) with a near immediate 'grab'
l. (Ideally) it would be repositionable / removable for a while before it sets PERMANENTLY.
m. (very ideally) it would be good to be weather proof
n. (ideally) it should be also reasonably priced – but that may be too much to ask!
In short, I'm looking for a better, long-life version of Sellotape that bonds permanently!
But I can see that I may need to compromise….
e.g. Maybe I could tolerate something that I have to apply with an iron or hot air gun??
YOUR SUGGESTIONS
My initial reactions are as follows:
> Model aircraft hinge tape
It looks interesting and might work OK, but it seems to be some sort of REMOVABLE tape, whereas I am looking form something permanent
> Core Series 2-1360.
Double-sided.
1mm will be a bit thick this project.
> fibreglass hinge
Surely glass fibres will start to crack if flexed too many times, no?
I don't want the hassle of mixing up an epoxy resin (1 minute of stirring an exact 50:50 mix etc)
> Kapton tape – polyimide film
Looks interesting.
Appears to resist high/low temperatures.
Not good resisting chaffing so not good in aeroplanes & spacecraft
https://en.wikipedia.org/wiki/Kapton
> Helicopter tape?
Is that the same thing as Paint Protection Film (PPF)?
i.e. A fough thermoplastic polyurethane tape, made by 3M
Originally developed by 3M as a film to stick onto helicopter blades to protect them from scratches and physical damage caused by high-speed impact with light debris such as airborne sand.
Nowadays used to protect vulnerable areas of cars & bikes
> Solartex
Is this it? **LINK**
It appears to involve "a special heatseal adhesive on the back of the fabric", although it's not very clear how to use this. If pushed, I suppose I could cope with apply it with the help of a domestic iron. I am assuming that a domestic iron c.150°C to 230°C. But as well as being rather a pain to use, wouldn't the heat melt my styrene/ABS??
However although the melting point of polystyrene is 240°C it starts to flow at over 100°C (it's "glass transition temperature"
And the glass transition temperature for ABS is "100°C"
So an hot air gun may be a mistake??
Any further thoughts?
Finally, what would be the best place for me to ask for general modelling type technical advice questions?
As I am building models of new commercial products that are IP sensitive, rather than models that fit nicely into any obvious category of model, such as "aircraft", "maritime", "locos" etc.
Many thanks
OP
