Inverter to run Qualter and smith power hacksaw
Home Forums Workshop Tools and Tooling Inverter to run Qualter and smith power hacksaw
  • #480191
    Lee Kennedy
      @leekennedy29914
      Morning all,
      I have a power hacksaw I haven’t used for some time due to no longer having 3 phase power.
      can I run this motor from an Inverter or is a motor inverter package the best option??
      thanks
      Lee Kennedy
        @leekennedy29914
        Which inverter or motor package
        #480197
        not done it yet
          @notdoneityet
          Have you checked on the rating plate to see whether it is wired as a dual voltage motor?
          The answer is more probably yes, but may need modifying.
          #480212
          Lee Kennedy
            @leekennedy29914
            I did try to attach a picture of plate. I will try again at home.
            the plate says 380/440v not 240/415.
            #480280
            Simon Williams 3
              @simonwilliams3
              ….and check the speed, as I have a hazy recollection that the one I used to have had a 6 pole motor on it. So if you wanted to swap the motor it would dance like a thing possessed running with a four pole motor.
              Though it's possible I've got muddled between this and a Wicksteed saw I also had back in the mists of time. The motor plate will tell you what the nominal full load speed is.
              HTH Simon
              #480305
              Lee Kennedy
                @leekennedy29914
                Simon,
                original motor is 950rpm.
                i have found a single phase motor 900 rpm. I will hopefully go with this.
                thanks
