inverter
inverter
Home › Forums › General Questions › inverter
  • #288340
    Richard Marsh 1
      @richardmarsh1
      Hi all,I have just bought a Colchester student 1800.I would like to know what would be the recommended inverter to use.The motor has at sometime been changed to a dual voltage single speed 2.2 kw 3 HP.Sorry if this has been asked before,I have looked at previous post's on this subject but didn't find what I was looking for.
      Rich.
      #25130
      Richard Marsh 1
        @richardmarsh1
        #288344
          Hello Richard
          Welcome to the forum. You will need a VFD that can deliver 2.2kW and wire the motor to run at 240V delta.
          MalcB
            @malcb52554
            Hi Richard,
            I have recently converted my Harrison M300 2.2kw 3hp with similar single speed motor using the Teco 2.2kw 230v single phase to 230v 3 phase Inverter EV series from Direct Drives.
            https://www.ebay.co.uk/itm/381471313429
            Edited By MalcB on 11/03/2017 20:07:39
            #288465
            Richard Marsh 1
              @richardmarsh1
              Thanks for the replies,much appreciated.
              #288493
              john fletcher 1
                @johnfletcher1
                I'm no expert ! but I altered the connections on a friends lathe motor from star to delta and fitted Huanyang 2.2 KW inverter which cost £90.40 via ebay, it was here in 4 days obviously not direct from PRC but some where here in UK. I have kept a copy of the programming should you or anyone else like a copy.I also I altered the lathe coolant pump so that it runs independently from a 240 volt supply, by reconnecting the motor to delta and then fitted, I think a 4 micro farad capacitor ex fluorescent lighting one. John
